1999 Kia Sephia Alarm wiring Diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=19100
Printed Date: March 30, 2026 at 7:52 AM
Topic: 1999 Kia Sephia Alarm wiring Diagram
Posted By: northballer
Subject: 1999 Kia Sephia Alarm wiring Diagram
Date Posted: September 20, 2003 at 7:57 PM
I need the wiring diagram so I can hook up this alarm with remote start also I've been looking everywhere and cant find it so please can someone help me thanks.
Posted By: StealthEs
Date Posted: September 20, 2003 at 8:10 PM
12volts red or black   +  steering column
Starter BLACK / YELLOW   +  steering column
Ignition WHITE/ blue   +  steering column
Power Lock add actuator    in drivers door
Power Unlock add actuator    in drivers door
Lock Motor
Unlock Motor
Disarm Defeat
Parking Lights+ blue/white    dash dimmer switch
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Door Trigger lt. GREEN/ red   -  drivers kick panel
Dome Supervision
Trunk/Hatch Pin
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer yellow    diagnostic connector
Notes: The diagnostic connector is located on the drivers side strut tower under the hood.
Horn Trigger blue/red   -  steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
posted_image
Immobilizer Bypass Module: Not Available
Cris
Date Posted: September 20, 2003 at 8:13 PM
DIRECTWIRE™ WIRING INFORMATION - LEXUS / ES 250 / 1990 / Remote Start
[PRINT THIS PAGE]
12volts
Starter BLACK/ white    ignition harness
Second Starter
Ignition BROWN / white    ignition harness
Second Ignition
Third Ignition
Accessory BLACK / YELLOW    ignition harness
Second Accessory blue/red    ignition harness
Keysense
Power Lock lt GREEN/ silver dot   -  pass kick panel wht plug
Power Unlock GREEN/ silver dot   -  pass kick panel wht plug
Lock Motor
Unlock Motor
Parking Lights+
Parking Lights- GREEN/ 2 silver dots   steering column black plug
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger RED / white   -  driver kick panel wht plug
Dome Supervision
Trunk/Hatch Pin RED / white    driver kick panel blu plug
Hood Pin RED / BLACK/ silver   -  alarm above glovebox
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock
Tachometer black    ignition coil
Wait to start
Brake Wire GREEN / WHITE    brake pedal switch
Parking Brake
Horn Trigger GREEN/ black   -  steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
posted_image
Cris
