diagram for 98 golf gti?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=19308
Printed Date: March 30, 2026 at 10:59 AM
Topic: diagram for 98 golf gti?
Posted By: johnnyd34
Subject: diagram for 98 golf gti?
Date Posted: September 25, 2003 at 8:10 PM
Can someone please help me with a wiring diagram for a 1998 VW Golf GTI. And if theres any special installation instructions i need ti install an avital 2200 alarm?
thank you very much
Posted By: profuse007
Date Posted: September 25, 2003 at 9:38 PM
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|red          10 ga.|+ |ign. harness - big          |
|          STARTER|RED / black     10 ga.|+ |loop at back of             |
|        IGNITION|black        16 ga.|+ |fuse box                    |
| SECOND IGNITION|*8                  |   |                            |
|        ACCESSORY|BLACK / YELLOW 12 ga.|+ |                            |
|       POWER LOCK|yellow/red or gray |+ |driver door harness in kick |
|     POWER UNLOCK|RED / blk or green *2 |+ |driver door harness in kick |
| PARKING LIGHTS +|gray/red, gray/black|   |back of lt.switch *3        |
| PARKING LIGHTS -|                    |   |                            |
|       HEADLIGHTS|WHITE/ black        |+ |back of light switch        |
|     DOOR TRIGGER|BROWN / white        |- |dr. kick or alarm mod *7    |
| TRUNK/HATCH PIN|BROWN / black        |- |dr. kick or alarm mod *7    |
|        HOOD PIN|BROWN / red           |- |behind fuse box             |
|TRNK/HTCH RELEASE|gray *4             |   |switch                      |
| FCTRY ALARM ARM|same as lock        |+ |                            |
|FCTRY ALRM DISARM|same as unlock *5   |+ |                            |
|       TACHOMETER|BLACK/ purple        |   |coil pack *1               |
|       BRAKE WIRE|RED / black           |+ |brake pedal switch          |
|     HORN TRIGGER|BLACK / YELLOW        |+ |behind fuse box             |
|           WIPERS|                    |   |                            |
| LF WINDOW UP/DN|not recommended *6 |   |                            |
| RF WINDOW UP/DN|not recommended *6 |   |                            |
| LR WINDOW UP/DN|not recommended *6 |   |                            |
| RR WINDOW UP/DN|not recommended *6 |   |                            |
Notes:
*1 The coil pack is located on the right side of the motor towards the front. *2 Requires a double pulse to unlock.   *3 Hidden release tab for light switch on upper left side of switch. Use relays to isolate the switch side of parking light wires from seeing 12v, or the igniton circuit will pulse with the light flash. It is also possible to use the hazard lights. The colors are BLACK/ white and BLACK/ green, and are positive trigger. They can be found at the alarm module or steering column. *4 Gray wire grounded by switch at rest. Use a relay to isolate the switch side of the trunk release wire from seeing 12v. *5 Use a single pulse to disarm without unlocking.   *6 Each power window motor is controlled by a module, the module and the window motor are built together as one piece, not allowing access to the motor wires *7 The alarm module is located behind the headlight switch. *8 There is a positive trigger key sense wire at the ignition switch or in the radio harness. the wire color is BROWN / red.
Houston,TX
