keyless problems
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=19368
Printed Date: March 30, 2026 at 12:35 PM
Topic: keyless problems
Posted By: mackytacky
Subject: keyless problems
Date Posted: September 27, 2003 at 1:57 PM
hi, I bought a bulldog RS1100 for my 97 Civic Sedan LX without keyless entry. I was trying to install the optional keyless entry and did what the manual said and wired everything right. But when I test it out, the doors won't unlock/lock and the module will just start clicking every time I press the lock/unlock on the remote? Any ideas?
Posted By: CruisinS&S
Date Posted: September 27, 2003 at 8:54 PM
the honda civic takes a neg. pulse to unlock and lock the doors. Does the rs1100 put out a neg pulse or pos. pulse output for the door lock wires? The wires on the civic should be GREEN / WHITE, GREEN/ org found in a blue plug in drivers kick panel
------------- Cruisin Security And Sounds
Posted By: Velocity Motors
Date Posted: September 27, 2003 at 10:23 PM
Check to see if the target wires actually activates the door lock system. If the door lock module isn't working, the door locks will not operate at all. The target wires rest at 12 volts and go to ground when activated.
------------- Jeff
Date Posted: September 30, 2003 at 9:10 PM
thanks for the responses, i got it working, and it works great. Thank you for all the help.
