remote starter 2001 honda civic
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=19514
Printed Date: April 19, 2026 at 2:23 AM
Topic: remote starter 2001 honda civic
Posted By: bmf1000d
Subject: remote starter 2001 honda civic
Date Posted: September 30, 2003 at 5:30 PM
I was wondering if the new 01 civics have the transponder or a vats system for the remote start. The wiring diagram software we have is out dated and the new has not shown up yet. I in the midwest were all i usually work on is chev ford and dodge. Any information with this would be helpful thanks.
Posted By: vaderfop
Date Posted: September 30, 2003 at 6:31 PM
12V|white             |+ |ignition harness             STARTER|BLACK/ white    |+ |ignition harness            |
IGNITION|BLACK / YELLOW |+ |ignition harness            |
ACCESSORY|BLACK/ red    |+ |ignition harness            |
SECOND ACCESSORY|WHITE/ red |+ |ignition harness
POWER LOCK|WHITE/ blue |- |gray plug above drivers kick|
POWER UNLOCK|WHITE/ green|- |gray plug above drivers kick|
LOCK MOTOR|yellow/black | |back of the fusebox *3      |
UNLOCK MOTOR|YELLOW /GREEN | |back of the fusebox *3      |
DISARM DEFEAT|yellow       | |back of the fusebox *3
PARKING LIGHTS -|blue   |   |factory alarm plug *1       DOOR TRIGGER|*2        |- |factory alarm plug *1       |
DOME SUPERVISION|comes on with unlock|   |        TRUNK/HATCH PIN|red   |- |factory alarm plug *1       |
TACHOMETER|blue        |   |test connector *4           |
SPEED SENSE|WHITE/ green | |PCM *5                      BRAKE WIRE|WHITE/ black        |+ |brake pedal switch
NOTE: This vehicle has an immobilizer system that needs to be bypassed when adding remote start. Use DEI part number 555I or 555U. *1 The factory alarm plug is a green plug above the drivers kick panel. *2 The drivers door trigger is green, front passenger door trigger is lt. GREEN/ red, and the rear door trigger is GREEN / WHITE. *3 In the top left plug. *4 It is a 2 pin plug to the passenger side of the battery. *5 The PCM is behind the glove box. The vss is in a connector A (31 pins), pin 18. The vss is also blue/white at the cruise control module to the left of the steering column.
hope this helps, be sure to check all this colors with a multi-meter
Jon
Posted By: bmf1000d
Date Posted: September 30, 2003 at 11:31 PM
Thanks for your help what wire software are you using? WireMagic?
"Big" Mike
Double Take
Fremont, Ne
remember to check all your wires with a dmm not a test light!!
i take no responsibilty whatsoever for the vailidty of the info nor consequences thereof
Posted By: vaderfop
Date Posted: October 01, 2003 at 2:21 PM
no, i use techsoft by DEI
Posted By: crich21
Date Posted: October 05, 2003 at 8:34 AM
Vaderfop is there any way a hobbiest like myself could get my hands on the latest techsoft by DEI program? I have a version that only goes to 99. It was given to me by a local installer years ago. I have searched the net extensively and have only found Designtech's program and I bought there book years ago and found the DEI is more accurate with wire colors.
Thanks in advance, Crich21
