Relay isolate door trigger then problems
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=19524
Printed Date: May 06, 2026 at 12:40 AM
Topic: Relay isolate door trigger then problems
Posted By: joedcrider
Subject: Relay isolate door trigger then problems
Date Posted: September 30, 2003 at 8:34 PM
I have a ford escape the alarm went off every 45 min. I read a topic here that says to isolate the door trigger with a relay, and it worked great for one day. and now the screen for the alarm says check door so I disconnected the door trigger wire all the way, and the screen still says check door. Is there some sort of rest for the alarm, or is it fried. It is a alpine 8063.
Posted By: gotoevolution
Date Posted: October 01, 2003 at 7:04 AM
You have to Diode Isolate the door triggers, use diodes, not relayes, that will solve your problem. Where did you get the door triggers from?
Date Posted: October 01, 2003 at 8:15 AM
There was a post here that said if diode isolate the dose not work you have to use a relay on some fords and the diode did not work it still went off every 45 min. Im using the green and black wire use to activate the dome light.
Date Posted: October 01, 2003 at 9:41 PM
Ok it works good no problems, the guys on this site KNOW THERE SH!T. New Relay was bad out of the package
