03 harley truck
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=19548
Printed Date: May 05, 2026 at 7:52 PM
Topic: 03 harley truck
Posted By: HARLEY4U2C
Subject: 03 harley truck
Date Posted: October 01, 2003 at 11:48 AM
hi i have a 03 harley truck and i purcahesd a crimestopper 2011 with the remote start which i want to install. i would like to get the wiring diagram for the truck and any instructions or tips for the install. thanks neil
Posted By: techker
Date Posted: October 02, 2003 at 6:13 AM
this is for a ford f series it is the same 2003.try it out
12 VOLTS yellow & lt. GREEN/ purple + ignition harness
IGNITION 1 dk. blue/lt. green + ignition harness
IGNITION 2 gray / YELLOW + ignition harness
IGNITION 3 lt. blue/pink + ignition harness Power this wire if vehicle is equipped with only rear anti-lock brakes. Vehicles with all wheel anti-lock brakes do not have this wire.
STARTER 1 RED / lt. blue + ignition harness
STARTER 2 n/a
ACCESSORY 1 RED / black + ignition harness
ACCESSORY 2 BLACK/ green + ignition harness
POWER LOCK pink / YELLOW passenger kick panel Negative pulse, type B, on keyless entry models. Five wire, type C, on non-keyless models, mastered from the driver switch.
POWER UNLOCK pink/green passenger kick panel Negative pulse, type B, on keyless entry models. Five wire, type C, on non-keyless models, mastered from the driver switch.
DISARM NO UNLOCK see factory alarm disarm
FACTORY ALARM ARM arms on lock w/door open Arms when locked with the door open. To simulate, send a negative trigger to the lt. blue/white wire at the RAP module, located behind the light switch, while locking.
FACTORY ALARM DISARM dk. GREEN/ purple - driver kick panel
DOORLOCK MOTOR pink/black 5wi driver kick panel
DOOR UNLOCK MOTOR RED / orange 5wi driver kick panel
PARKLIGHTS POSITIVE brown + headlight switch May also be found at the trailer connector next to the diagnostic connector under dash.
PARKLIGHTS NEGATIVE lt. GREEN/ YELLOW - headlight switch If equipped with autolamps.
BRAKE lt. green + brake pedal switch May also be found at the trailer connector next to the diagnostic connector under dash
DOOR PIN blk/yel (l) & blk/pnk (r) - each door harness The BLACK / YELLOW catches the driver door and the BLACK/ pink catches the passenger door. The wires are found in their respective door harness. On the Super Crew the rear door trigger is BLACK/ lt. blue low in the driver kick panel. Use all wires and diode isolate each from the GEM module, refer to DirectFax document 1076 for wiring information.
HOOD PIN n/a
TRUNK PIN n/a
DOMELIGHT SUPERVISION BLACK/ lt. blue + passenger kick panel
TACH ac On the 4.2L it is dk. blue/lt. green at the coil pack on top of the motor. On the 4.6L go to any of the ignition coils and use the wire that is NOT RED / green. On the 5.4L it is lt. GREEN / WHITE at the coil on the passenger side of the motor between the fuel injectors.
TRUNK RELEASE n/a
SLIDEDOORS n/a
HORN dk. blue - steering column
------------- techker
Posted By: chuckles
Date Posted: October 02, 2003 at 3:43 PM
I put the same alarm on my 2003 King Ranch, It wasn't that big of a job. The only thing I had to do in addition to all the other stuff was to mount a relay for the automatic headlights so they would not come on during remote start. Power the relay off the ignition switch and pick up the lights AFTER the photocell or they will come on every time you turn the key on.
Good Luck! Chuck
