clutch bypass
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=19624
Printed Date: May 05, 2026 at 1:10 AM
Topic: clutch bypass
Posted By: Skyler08
Subject: clutch bypass
Date Posted: October 03, 2003 at 2:27 PM
I'm trying to bypass my clutch for a remote start. i found the purple and yellow wire but I dont know if my clutch is neg. or pos. it for a grand am 1997 if anyone could help me bypass it that would be great. thanks
Posted By: 12voltassassin
Date Posted: October 03, 2003 at 3:09 PM
well sometimes you need to cut both wires at the same time with a relay or one of them needs to be cut and the other always connected you need to use a test light to find out or a dmm. push the clutch while probing the wires and then youll know
------------- i hate ebay they are stealing my business
Posted By: rudbwoy69camaro
Date Posted: October 03, 2003 at 3:55 PM
I need to make a short video of my car in first gear, with the e-brake off and RS it. I wonder how much it would travel... on flat ground. I'll name it, "remote start, my dumbass, and leaving it in gear."
Posted By: Velocity Motors
Date Posted: October 03, 2003 at 7:23 PM
Do you have a remote starter that is designed to start manual transmission vehicles??
------------- Jeff
Posted By: whitey
Date Posted: October 03, 2003 at 8:26 PM
Providing that are using a car starter for a manual, feed your + starter lead to the heavy purple wire at your clutch. That will start your car.
Posted By: SiFi
Date Posted: October 05, 2003 at 8:38 AM
Another thing you can do is use the blue wire from the remote start to power a relay that would short the two wires together. That's basically what the switch is doing every time you step on the clutch.
