where 2 mount 2-way pager alarm antenna
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=1967
Printed Date: April 28, 2026 at 2:43 PM
Topic: where 2 mount 2-way pager alarm antenna
Posted By: 2000vsm
Subject: where 2 mount 2-way pager alarm antenna
Date Posted: July 15, 2002 at 7:28 PM
I got the aladdin a-2000.. it's a big unit.. wondering whree can i mount it so it's hidden but also good range... cuz right now it's in my sunvisor clipboard and the range is crap...
Posted By: Velocity Motors
Date Posted: July 16, 2002 at 12:59 AM
Hey 2000vsm, did the sales person tell you about the resistor to cut to get 2x the range on the module ? If you can, take the casing apart on the communication module and slip the board between the roof liner and the roof. ------------- Jeff
Posted By: TheRapture
Date Posted: July 16, 2002 at 1:34 PM
i've got my 2-way FM antenna in the upper part of my dash above he insterment cluster... should i try taking out of the case also? it's an Black Widow 2-way
Date Posted: July 17, 2002 at 12:38 AM
I'm not familiar with the antenna that the Black Widow comes with , but the Aladdin antenna's have a bulky casing that you can unscrew 4 screws and take out the board and it is 1/3 the thickness and 3/4 of the size. If the Black Widow has a case simliar to the Aladdin, I would suggest taking it apart so that you can fit it in smaller spaces and hide it better. ------------- Jeff
Posted By: 2000vsm
Date Posted: July 17, 2002 at 10:04 AM
what resistor.. is it in the brain, like under the board there is this soldered resistor.. do i cut that one? i want more range.. sucks right now hey if i hide it.. how can i press the button? is it ok to put it in my glove box? there's not much metal there..
Posted By: 2000vsm
Date Posted: July 17, 2002 at 11:55 AM
need the 2x range!!
Date Posted: July 17, 2002 at 1:08 PM
The resistor is in the communication module. There is a silver piece of tape on the side covering the resistor..... just cut it away from the module. ------------- Jeff
Posted By: 2000vsm
Date Posted: July 17, 2002 at 2:38 PM
just cut it away like cut it in half or take it out completely?? also i opened up some of my brains of the a2000 and there is a resistor soldered on the back side of the brain.. what is that for?
Date Posted: July 18, 2002 at 7:20 AM
Doesn't matter if you cut it away or if you just cut in half. As for the resistor in the CPU..... we don't go in there, voids your warranty. ------------- Jeff
Posted By: 2000vsm
Date Posted: July 18, 2002 at 12:06 PM
how about i put the antenna inside my sunvisor. like take out my mirror in the sunvisor and put it there.. or in my glovebox area?
Date Posted: July 18, 2002 at 12:57 PM
The sunvisor is a good place to slip it into. The glove box may have too much EMI that will reduce your range but try both places and see which is better for the range. ------------- Jeff
