commando 357 alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=19746
Printed Date: May 06, 2026 at 8:36 PM
Topic: commando 357 alarm
Posted By: jacktowncruiser
Subject: commando 357 alarm
Date Posted: October 06, 2003 at 10:12 PM
Im trying to install a commando 357 alarm in a 81 pontiac grand prix and for some reason when I just hook up the power wire and ground wire the alarm just goes off..can someone tell me how to find the door pin switch?
Posted By: floaterr
Date Posted: October 07, 2003 at 9:50 AM
Well the good news is it more then likely doesn't have an on board computer that you have to worry about the test light frying.
Use the dome light (or lights under the dash) if you cannot get to the door pin sw or if it is built into the door latch mech. Did you look on the side of the dash? I didn''t think they started hiding the pin switches till the 90's.
