Chevy Tahoe Tach Wire?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=2001
Printed Date: April 03, 2026 at 3:48 AM
Topic: Chevy Tahoe Tach Wire?
Posted By: SCOTT105
Subject: Chevy Tahoe Tach Wire?
Date Posted: July 16, 2002 at 11:49 PM
Where is the best possible place to find ths wire
Posted By: trusdamanr
Date Posted: July 17, 2002 at 10:54 AM
what year is it
Posted By: Big Dog
Date Posted: July 17, 2002 at 1:41 PM
Hey SCOTT105,
The tach is always white at the ECM no matter what year.  However the placement of the ECM is different dependant on year.  For example year 2000 and older,  the ECM is located on drivers' side inner fender. Tach wire found in a black plug marked "white".  In newer vehicles the ECM is located near the battery, down low, between the fender and the fan under the black plastic cover. On the 4.3L, the tach wire is at pin 20 in the connector labeled "red". On the 4.8L, 5.3L, and 6.0L, the tach wire is located at pin 10 in the "red" connector.  Hope this helps!  posted_image
Prepare your future. It wasn't the lack of stones that killed the stone age.
Posted By: SCOTT105
Date Posted: July 17, 2002 at 3:15 PM
sorry it is a 1996 chevy tahoe
Posted By: mobiletoys2002
Date Posted: July 17, 2002 at 6:17 PM
your wire should be white. you can get this wire at the coil on the passenger side of it.
