Few Aladdin 2000 Questions
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=20185
Printed Date: May 06, 2026 at 8:42 PM
Topic: Few Aladdin 2000 Questions
Posted By: superthug
Subject: Few Aladdin 2000 Questions
Date Posted: October 16, 2003 at 9:40 AM
I have the alarm installed already and it work great but here's few things I want to know more about.
1) How would I wire an air horn to work with the alarm?
2) I have a 91 integra 5-spd and I'm trying to put remote start. The white(?) wire from the aladdin brain supplies (-) charge, which wire by the clutch pedal should I connect to?
3) How can I buy another remote for my alarm? Just in case I lose mine.
Posted By: Velocity Motors
Date Posted: October 16, 2003 at 2:33 PM
1. From the P10 harness use the BROWN wire and wire it to a 5 SPDT relay like so. This will convert the (-) signal of the BROWN wire to a (+) that you can wire up to the (+) on the air horn 2. Positive Clutch Bypass Circuit Negative Clutch Bypass Circuit 3. The remote controls are expensive because of the micro circuitry board and vibrator motor in them. Replacement remotes can be purcahsed through us. ------------- Jeff
Date Posted: October 16, 2003 at 4:41 PM
2. How would I know which clutch bypass circuit I have? I have a 91 integra.
3. How much do the remote cost?
Thanks.
Date Posted: October 17, 2003 at 5:43 AM
2. You have a negative, but use the link above to test the circuit for sure. DO NOT ASSUME anything with vehicles as you might have a vehicle that for some reason is different than any other's 3. $ 109.00 USD ------------- Jeff
Date Posted: October 26, 2003 at 5:48 PM
I tried to get the remote start working and the parking lights just flash and the remote shows the car starting but nothing happens. I checked the dip switches, the brown loop is uncut and the tach is programmed fine. I even sat in the car and put the clutch down but it didnt start. The thing is when I press E and take the key out the car shuts off.
Also, the brain is not giving a ground anymore to the siren for some reason. The brown wire. I dont want to open everything up and check is there any other way I can hook up the siren to go off when the alarm goes off? Maybe use the parking light wire? Just a suggestion.
Need ur help Jeff, help me out man.
Date Posted: October 26, 2003 at 7:25 PM
You have two IGN wires to hook up, did you hook them both up ? Also, when you say " nothing happens" do you meant hat the car doesn't even attempt to turn over ? Make sure that you have the door trigger wire hooked up properly as well otherwise the remote start sequence will not work. YOu have to enter into ready mode in order for the remote starter to work at all.
------------- Jeff
Date Posted: October 26, 2003 at 7:36 PM
I hooked up the 1st ignition wire (p6 yellow) and the other (p9 gray) one i had to convert the polarity of the alarm output to make it work. Yeah the car doenst attempt to turn over. The door trigger is working fine because when i arm the car it doenst say door open. Is there anything else i should check?
For the siren not working, I have an idea...I use the p3 yellow wire that goes to the parking lights. and use it to power the siren, air horn, and 4 strobe lights. Is it possible? how would i wire up the relays to work?
Date Posted: October 26, 2003 at 8:01 PM
Did you program the GRAY & the WHITE wires for the correct function as well ? As far as the YELLOW wire for the light control, you can use relays and use the YELLOW wire as your trigger wire. Wire up the devices that require a (+) input to turn on with this relay configuration and for the devices that require a (-) input to turn on use this relay configuration ------------- Jeff
