door pin false out...How to relay?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=20232
Printed Date: May 07, 2026 at 5:33 PM
Topic: door pin false out...How to relay?
Posted By: oakley3
Subject: door pin false out...How to relay?
Date Posted: October 17, 2003 at 1:51 PM
2000 Ford Taurus.
I hooked up my door pin wire today(BLACK/ light blue) and let it sit for an hour with it armed like I was told. When I came back and disarmed, it chirped several times and my LCD screen on my remote flahed the door indicator. So I guess it falsed out. So my question is...how do I hook this up with a relay? Any diagrams would be very helpful or you can just try to explain your best. Thanks alot!
Posted By: derek123
Date Posted: October 17, 2003 at 2:29 PM
black blue is + door trigger on that car, no ?
If so:
85 to BLACK/ blue on the car
86 ground
87 fused constant 12 volts +
30 to the + door trigger input on you alarm.
the pulse on the line is absorber by the coil, but when the door opens it still triggers the relay to send +12 to the alarm input.
Posted By: oakley3
Date Posted: October 17, 2003 at 3:15 PM
Thank you! Yes it is + on my car. I will try it out.
