1L3Z-19G365-AB bypass for ford escape2003
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=20331
Printed Date: May 09, 2026 at 2:56 AM
Topic: 1L3Z-19G365-AB bypass for ford escape2003
Posted By: urmyace
Subject: 1L3Z-19G365-AB bypass for ford escape2003
Date Posted: October 20, 2003 at 5:53 AM
What is the wiring diagram for this, Not sure how to hook this up, any help would be apreciated, thanks
Posted By: NowYaKnow
Date Posted: October 20, 2003 at 4:41 PM
"1L3Z-19G365-AB bypass for ford escape2003"
You want to hook up the red wire to 12v+ constant, and the black wire to the active out (-) or the ignition 3 (-) out on your module. You didn't mention what kind of remote start your using, let us know and maybe someone can tell you the exact wire. You can cut the white wire off and tape it up you don't need it. Also you'll want to take that bypass back because it won't work on an escape who sold you that?! You need the 1S4Z-19G365-AB bypass..Good luck,
Mike
Posted By: urmyace
Date Posted: October 20, 2003 at 6:38 PM
I am using the design tech 20023, I posted the incorrect numbers on the module, you were correct with the number you have. thanks
Date Posted: October 20, 2003 at 6:46 PM
Ok then you want to use the ignition 3 (-) WHITE/ black wire off of the module to the black wire on the bypass. Then tie the red wire into constant 12v fused, and cut off and tape the white wire as you don't need it. Hope that helps,
Mike
Posted By: urmyace
Date Posted: October 24, 2003 at 4:20 PM
Didn't seem to work, any suggestions ??
Date Posted: October 25, 2003 at 1:32 AM
What seems to be the problem? Also did you program the bypass? If not, here's how you'll need at least 2 keys and all the keys you have for the car if more than two.
Basically get the remote start all programmed up and ready to go meaning tach is learned if your using it etc. Now take your first key and turn the ignition ON. Watch the theft light in your dash come on solid for a few seconds. As soon as the theft light goes out remove the first key and put the second key in and turn the ignition on. Again watch the theft light and as soon as it goes out remove the key and push the start button on your remote start. The ignition should come on and the theft light should be solid and then go out. If the theft light blinks hit the brake because it didn't take..Retry the procedure..Also you have to do the whole thing fairly quickly. Good luck
Mike
