2003 dodge caravan
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=20359
Printed Date: May 09, 2026 at 3:07 PM
Topic: 2003 dodge caravan
Posted By: misterjimbo
Subject: 2003 dodge caravan
Date Posted: October 20, 2003 at 8:14 PM
any diagrams/location charts. I do not do many chryslers (2 in last 3 years) can you offer me any tips? thanks alot.
Posted By: 10nesne1
Date Posted: October 20, 2003 at 9:33 PM
Here is the 2003 Dodge Carvan Wirings.
2003 Dodge Caravan
Good luck.
Posted By: Velocity Motors
Date Posted: October 20, 2003 at 9:46 PM
Make sure that all IGN wires are powered up & that the power wire is straight to the battery because the constant wire under the dash is only rated at 10 amps. Also DO NOT use the (+) parking light output, use the (-) only. There is a 2nd starter wire as well that you need a relay for because it is a (-) trigger starter wire through a 180 ohm resistor.
Posted By: NowYaKnow
Date Posted: October 21, 2003 at 5:12 AM
"power wire is straight to the battery"
There is a thick WHITE/ red constant wire up by the bcm under the dash. Not sure what it's rated at but I've always used that for my constant and never had a problem. Since most everything in that car is negative and the ignition wires are tiny you shouldn't need a ton of power anyway. Of course power wire straight to the battery (fused of course) is always a good idea so either should work just throwing out another idea..
Posted By: GottaBNeat
Date Posted: October 21, 2003 at 9:34 PM
violet/brown is a second starter,not ignition.
Posted By: jb30
Date Posted: October 21, 2003 at 11:12 PM
using the WHITE/ red under the dash is fine for power, I have done too many of these to count and have used that wire evry time.  make sure you put the PURPLE / brown as sec. starter or else the heater fan will never turn on.
Date Posted: October 23, 2003 at 6:58 PM
thanks guys audiovox tech sheet says that ign 2 and ign 3 are multiplex and that they do not need to power them up is this true????
Posted By: csorb
Date Posted: October 23, 2003 at 7:36 PM
I don't believe you need ignition2 and 3. One ignition works fine. Also if you use the 555C and are using the same negative as for the 2nd starter relay,   you have to diode isolate it to the relay or the accessories shut off when the remote starter's not running.
Date Posted: October 26, 2003 at 8:23 AM
No need to hook up the other IGN wires and also, no need to hook up the ACC wire either. It will come on when you remote start the van.
Posted By: whiteshack
Date Posted: October 27, 2003 at 8:15 AM
i did about 2 of these vans on the chy.town and country lx model i did not power up the second ign van works fine but on the other i had too because heater will not power up unless 180ohm resistor was used...Whiteshack Electronics.
mecp certified installer
