disabling alarm on gmc 2500
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=20479
Printed Date: May 13, 2026 at 11:13 PM
Topic: disabling alarm on gmc 2500
Posted By: doomstr
Subject: disabling alarm on gmc 2500
Date Posted: October 23, 2003 at 1:08 PM
My grandfather has a 2000 gmc 2500. He says the alarm drives him nuts. He just wants it deactivated. Is there a simple way to disarm so everything else still works (pwr locks) or does he need a bypass kit? If so will they get rid of the alarm altogther? Most of what Ive read so far is just about people wanting to install remote starters. Thanks for the help
Posted By: derek123
Date Posted: October 23, 2003 at 1:54 PM
the owners manual should have a section on how to set up the alarm.
Posted By: doomstr
Date Posted: October 23, 2003 at 7:03 PM
I want to turn it off so it never comes on again
Posted By: italnpimp59
Date Posted: October 23, 2003 at 9:35 PM
what year is it? -------------
Posted By: daniel2002p
Date Posted: October 24, 2003 at 6:52 AM
Factory alarm or aftermarket?
------------- 2005 Toyota Corolla S
1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
Posted By: doomstr
Date Posted: October 24, 2003 at 8:07 AM
its a 2000 with a factory alarm
Date Posted: October 24, 2003 at 11:36 AM
Find the alarm module in the drivers kick on the fire wall and cut the 12v leading to the alarm. This should take care of it and the door locks will still work. The remote will be of no use anymore though.
1.8L VVT-i I-4
Posted By: auex
Date Posted: October 24, 2003 at 12:31 PM
Hold on there, don't go cutting wires yet. Is it a factory alarm or a dealer installed alarm? If it is a factory alarm the dealership can disable it, this type runs through the computer of the car, or if you look hard enough you can find instructions on how to do it yourself. If it is a dealer installed alarm then just pull the fuse on the red, at least usually red, wire going to the brain.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Date Posted: October 24, 2003 at 3:48 PM
Actually this years does not go through the computer, it is a stand alone alarm module. I have done these before and I just interrupoted the 12v wire and it took care of it.
1.8L VVT-i I-4
Posted By: Velocity Motors
Date Posted: October 26, 2003 at 8:05 AM
Take the LIGHT GREEN wire found in the purple plug of the BCM and take a jumper wire to ground. This will permanently disarm the alarm and it will never re-arm itself so long as the jumper wire is attached to ground.
------------- Jeff
