black eagle remote starter
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=20533
Printed Date: May 14, 2026 at 9:29 PM
Topic: black eagle remote starter
Posted By: yomamas
Subject: black eagle remote starter
Date Posted: October 24, 2003 at 10:13 PM
this is my first post so i hope its in the right place.
i have a black eagle model rs810a remote keyless entry starter that is on a 93 chevy pickup.the problem i have is i lost the remote for awhile and the battery died.i replaced it but now it dont work on my truck.the box under the dash has a hole covered by a rubber piece that slide to the side.it also has 3 dip switches on it with 1 differant pos.the remote has 3 buttons that only 2 worked ,1 to unlock and 1 to start. how do i make it work again?anyone have a instruction manule for a black eagle?  thank for any help
yomamas
Posted By: yomamas
Date Posted: October 28, 2003 at 4:25 PM
HERES MY PROBLEM anyone have any suggestions please let me know
yomamas
Posted By: cpgoose
Date Posted: October 30, 2003 at 9:46 AM
Did all 3 buttons work before you replaced the battery in the remote?
Maybe try unplugging the wiring harnesses going to the module for a bit, and then plug them back in. Maybe that will let the remote work again.
Q: What's the best nation in the world?
A: Donation!     Donate to the12volt.com
Posted By: yomamas
Date Posted: October 30, 2003 at 10:16 AM
first thanks for the reply
no only the top lock/unlock  and the bottom start worked.
the funny thing is, after i lost the remote its been about a year,the doors started to lock when you start it with key and unlock when you shut off.
it only locked before when you used the remote start never unlock.
someone told me to open door,turn key on -off 4 times all with foot on brake,then push top button on remote.you can hear the box click,butit wont do anything else.
i really want to use this again,so i need to find out what to do and i dont know where else to look.
please let me know if you have any ideas
thanks again
yomamas
Posted By: yomamas
Date Posted: November 10, 2003 at 7:30 PM
anyone help please!!!!!!
Posted By: cpgoose
Date Posted: November 12, 2003 at 7:25 AM
So only the button that controls lock/unlock worked, and the button that controls remote start? Now nothing works at all...even though you replaced the battery?
Did you try my suggestion about unplugging the harness for a while, and then plugging it back in?
Posted By: yomamas
Date Posted: November 12, 2003 at 9:54 AM
yes i tried unhooking the box ,i took it out of the truck for about 1/2 hour but it did the same thing. just the top[unlock] and bottom[start] buttons were the only ones that ever worked before,now the top makes the box click when you try to program as i said above. any more suggestions?
thanks
yomamas
Posted By: cpgoose
Date Posted: November 12, 2003 at 1:07 PM
Sorry dude, I'm running out of ideas.
I guess the next thing would be to try to find the install manual...but I can't find it anywere.
Posted By: JWorm
Date Posted: November 13, 2003 at 12:19 AM
I used to install that crap a couple years ago. Probably the worst product I've used out of 5 different brands over 6 years of installing.
Unplugging it and plugging it back in will usually do the trick. If it doesn't, you may need to reprogram the remotes. I think this is how you do it.
Open door
Foot on brake.
Key on and off 4 or 5 times....leaving it in the on position
Hit button 1 on the remotes.
