Excalibur AL-700LC Alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=20833
Printed Date: March 24, 2026 at 2:17 PM
Topic: Excalibur AL-700LC Alarm
Posted By: Taysey22471
Subject: Excalibur AL-700LC Alarm
Date Posted: November 01, 2003 at 1:48 AM
I have just acquired this used alarm system(Excalibur AL700LC).  I can only find VERY vague info on it.  No wiring or installation info.  I am installing it on a 95 Pontiac Grand Am GT - w/o factory keyless entry and/or security.  Can anyone help please?!!!!
Thanks!
Trace
Posted By: draasch
Date Posted: November 04, 2003 at 6:58 AM
here you go........1-800-554-4053
www.caralarm.com
Make:   Pontiac
Model: Grand Am
Year:    1995
This Database Was Last Updated On:    6/9/03
Index #: 9746
Alarm
Constant 12 volts RED & RED IGNITION SWITCH HARN.(BOTH 1 CIRCUIT)
Ignition 12 volts PINK IGNITION SWITCH HARNESS
Starter YELLOW IGNITION SWITCH HARNESS
Dome Light LT.GRN/BLK & LT.BLU AT CONVENIENCE CENTER MODULE *
Trunk Pin Switch BLACK (-) TRUNK SWITCH OR LIGHT
Parking Lamp BROWN (+) AT HEADLIGHT SWITCH **
Power Lock L BLUE GRAY 24 PIN CONN. TO #202
Power Unlock WHITE LEFT OF STEERING COLUMN
* Convenience Center Module Located Behind Driver Dash Above Fuse Block. L GREEN/ BLACK (-) Covers Driver Door, L BLUE (-) Covers All Other Doors. Diode Isolation Needed: Cathode (Band Side) Faces OEM Wires. ** BROWN (+) Wire Can Also Be Found In 24 Pin Connector To Left Of Steering Column. See Tech Notes #202- See Positive Pulse Door Lock Diagram
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
