Need 94 Mitsubishi Montero Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=20893
Printed Date: March 25, 2026 at 9:45 PM
Topic: Need 94 Mitsubishi Montero Wiring
Posted By: TheKrownedKing
Subject: Need 94 Mitsubishi Montero Wiring
Date Posted: November 02, 2003 at 3:01 PM
First off, any and all information will help and will be greatly appreciated.
To the point...  I need info on installing an alarm in my 1994 Mitsubishi Montero SR 3.5. The alarm is a DEI HORNET 554T. I will be using all of the standard features of this alarm and also two additional add-ons, a Dual Zone Microwave Radar Sensor and a Power Window Control Module.
Any info, diagrams, charts, pics, tips, hints, whatever, would be an ENORMOUS help since this will be my first alarm install. I just finished with my stereo install and let me tell you that was a serious pain in the (tailpipe)! Encountered numerous unexpected delays in the project, and would like to hopefully prevent any with this job if possible. So all your help will help.
Posted By: Javelin3o4
Date Posted: November 02, 2003 at 10:01 PM
|              12V|white               |+  |ignition harness            |
|          STARTER|blu/blk or blk/yel  |+  |ignition harness            |
|         IGNITION|BLACK/ white         |+  |ignition harness            |
|        ACCESSORY|blue/red            |+  |ignition harness            |
| SECOND ACCESSORY|blue / YELLOW         |+  |ignition harness            |
|       POWER LOCK|BLACK/ red           |-  |upper harness in driver kick|
|     POWER UNLOCK|BLACK/ blue *2       |-  |upper harness in driver kick|
|       LOCK MOTOR|WHITE/ black         |   |drivers kick panel          |
|     UNLOCK MOTOR|blue/orange         |   |drivers kick panel          |
|    DISARM DEFEAT|blue/red            |   |passengers kick panel       |
| PARKING LIGHTS +|GREEN / WHITE         |   |lower harness dr. kick      |
| PARKING LIGHTS -|GREEN / WHITE         |   |headlight switch            |
|       HEADLIGHTS|red                 |-  |headlight switch            |
|     DOOR TRIGGER|GREEN/ red *3        |-  |lower harness dr. kick      |
|  TRUNK/HATCH PIN|tied in with doors  |   |                            |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|                    |   |                            |
|       TACHOMETER|white               |   |at igniter *1               |
|      SPEED SENSE|yellow/white        |   |data link connector *4      |
|       BRAKE WIRE|green               |+  |at switch                   |
|     HORN TRIGGER|GREEN/ red           |+  |horn or relay underhood     |
|           WIPERS|blu/red(L),blu/blk(H|+  |steering column             |
|  LF WINDOW UP/DN|red - green         |A  |drivers door switch         |
|  RF WINDOW UP/DN|RED / blu - blk/blu   |A  |drivers switch or kick panel|
|  LR WINDOW UP/DN|RED / wht - grn/wht   |A  |drivers switch or kick panel|
|  RR WINDOW UP/DN|RED / yel - grn/yel   |A  |drivers switch or kick panel|
| SUN RF OPN/CLOSE|black - green       |A  |motor behind sunroof        |
| RADIO ILLUMINATE|GREEN / WHITE         |+  |radio                       |
|    POWER ANTENNA|WHITE/ black         |+  |radio                       |
Notes:
*1 Igniter buried in stuff at top rear of engine.   Six wires in harness at small module.  Also found the same color at the ECM in the passenger kick. it is in the center plug.   *2 Also reported as BLACK / YELLOW for unlock with alternate location at relay behind drivers side speaker.  *3 Use GREEN/ red if equipped with factory keyless entry.  The non-keyless models are GREEN/ orange.  *4 The data link connector is under the driver side dash, near the relay box.
Date Posted: November 08, 2003 at 2:24 PM
Holy Smokes! That aughtta do er!!  Hey thanks for all the info and your time!! Very Much Aprreciated!!  Exactly What I Was Looking For! PEACE!!!!!!
