Auto Start Chevy Prizm Lsi 1998
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=20924
Printed Date: April 18, 2026 at 10:21 PM
Topic: Auto Start Chevy Prizm Lsi 1998
Posted By: dancower
Subject: Auto Start Chevy Prizm Lsi 1998
Date Posted: November 03, 2003 at 1:19 AM
hi, I'm trying to install an remote auto start to Chevy Prizm Lsi 1998. In the diagram that i get from the product, there is one Coil says "High Voltage Coil", and it also says "Wind around the coil for at least 5 circles) for the kill relay. Where can I find the coil, and which part of the coil should i wind the wire to? thanks a lot dan
Posted By: dancower
Date Posted: November 03, 2003 at 5:26 PM
hi, I'm trying to install remote start to Chevy Prizm 1998, but I don't undertand about the Starter kill. I also include the picture from the diagram. which one is the tachometer wire? the starter kill relay output or starter sensing input? and this two wire like shown in the diagram attach to two different place of the coil. And I try to find the wiring diagram from the car, it only tell the tach wire. So what kind of wire is the buttom of the coil and what kind of wire is the one that has to be winded at least 5 circle, and I don't understand where should i wind the wire too. Please help If anybody know about this diagram. What happen if I didn't connect the starter kill, can i still start the car with remote? what about others thing like alarm, turn on the heater and everything? thank you very much dan
Posted By: misterjimbo
Date Posted: November 03, 2003 at 8:14 PM
that diagram os confusing and i have been doing this for years... here is how to do a starter kill... take the trigger from the alarm and connect it to pin 86 take pin 85 to ignition 1 (hot in the crank) cut the starter wire and put one end to 87a and one end to pin 30. it does not matter which cause it is basically only a switch. there are a few ways to wire a starter killl but this is probably going to be the easiest for you. As for your tach signal go to a coil pack if you can. check the vehicle wiring section of the site for other tach wires. hope this helps
Posted By: dancower
Date Posted: November 03, 2003 at 9:42 PM
ok i get you. now i understand. thanks misterjimbo.
Posted By: dancower
Date Posted: November 04, 2003 at 11:10 AM
hi, i still have problem finding the tach wire. I couldn't find the distributor for this car. Does anybody know where I can find the tach wire for Chevy Prizm Lsi 98 which is similar to Toyota corolla. thank you very much dan
Posted By: padawan
Date Posted: November 04, 2003 at 11:19 AM
Find the distributor cap, the round thing with all the spark plug wires coming out of it, that's where the distributor is...
If not, find the coil, it's the thing that has 1 spark plug wire going into it, the wire comes from the distributor cap...
If not, get the wire at a fuel injector, on the injectors there will be 2 wires, 1 wire color will be the same on all of the injectors, the other wire color will vary from injector to injector, hook up the tach to a wire that varies in color...
Test for the tach at coil or distributor, place red lead of multimeter on wire, black lead to ground, set meter to read AC voltage, start the car, should read from 1-6V, rev the engine, voltage will go up, that will be the wire u need...
Date Posted: November 04, 2003 at 4:36 PM
as a last resort you can run it tachless... just switch it in the menu the prism cranks slow so you won't get too much over crank but like i said it is a LAST RESORT!!!!!!
Posted By: dancower
Date Posted: November 05, 2003 at 3:12 PM
hi, I have a problem finding tach signal wire (remote start purpose) in ECM (no distributor) system for my Chevy Prizm 1998 which is similar to Toyota Corolla 1998. Anybody know how to find the tach reference. Please Help. thank you very much dan
Posted By: camry0099
Date Posted: November 05, 2003 at 4:17 PM
It's a black wire on the ecm located behind the center console. Remember, always double check before making final connection. I hope that helps.
Posted By: dancower
Date Posted: November 06, 2003 at 11:36 AM
would you mind to tell me how to check the tach signal, camry 0099? thanks
Posted By: dancower
Date Posted: November 06, 2003 at 11:54 AM
I'm installing a remote start for chevy prizm 1998, I hooked up all of the wire except the tach wire, because i couldn't find it. after that I'm thinking of trying the keyless entry, so i hooked up the brain and the sensor too. what happen was when i push the door lock key from remote, the siren crips once, the brain produce some sound, and i heard litlle sound from the driver's door panel, too. But the door didn't lock, including others door. And the parking light didn't blink also. when i push the unlock key from remote, nothing happened too, just the siren crips twice, and litlle sound from the brain. one more think is, when i try to go inside programming mode, the led suppose to blink 3 times if the remote works, but it didn't blink at all. I try couple times, same thing happened. but like i said before, when i push lock or unlock key from remote, the sirene will crips. so, i think the remote works. This car has a little problem with the door before I install the system. This car have 2 central lock, one at the driver's side and another one at the passenger side. When I open the door using key, it only open the driver's door, others door still keep locked, but when I open the door from passenger side with key, all the doors will open. And both the driver side and passenger side central look switch at the door panel work fine, I mean when i push lock position all doors will lock, and if i push unlock position all door will unlock. What do you guys think wrong with this? I tried to find the wiring diagram from here and it said that the lock and unlock signal with (-) sign, so I assumed that this is the negative system and I hooked up the othe wire from the brain to positive +12V wire, is that right? Please help, I don't know what to do anymore, this is my first time installing remote start. thank you very much dan
