98 pathfinder keyless module?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=20957
Printed Date: April 18, 2026 at 9:21 PM
Topic: 98 pathfinder keyless module?
Posted By: Giovan101
Subject: 98 pathfinder keyless module?
Date Posted: November 03, 2003 at 5:00 PM
I am installing a remote start/keyless enrty on a 98 pathfinder. Where is the keyless entry module located? I think its under the dash but where?
Posted By: draasch
Date Posted: November 04, 2003 at 6:51 AM
Make:   Nissan
Model: Pathfinder
Year:    1998-99
This Database Was Last Updated On:    6/9/03
Index #: 450
Alarm
Constant 12 volts WHITE/ PURPLE IGNITION SWITCH HARNESS
Ignition 12 volts BLACK/ WHITE IGNITION SWITCH HARNESS
Starter BLACK / YELLOW IGNITION SWITCH HARNESS
Dome Light RED / BLACK (-) DRIVER KICK PANEL *
Trunk Pin Switch RED / BLACK (-) SAME CIRCUIT AS ABOVE
Parking Lamp PINK/BLUE (+) AT HEADLIGHT SWITCH
Power Lock L GREEN/ RED 16 PIN WHITE CONNECTOR ** #201
Power Unlock BROWN IN DRIVER KICK PANEL
* With Oem Alarm Only: RED / BLACK (-) Changes To RED / BLUE (-) In Driver Kick Panel. ** Door Locks Also Located At "Smart Entry Control Timer" Behind Left Side Of Driver Dash On Right Side Of Fuse Block. #201- See Negative Pulse Door Lock Diagram.
Remote Start
Tach Signal WHITE AT ENGINE CONTROL MODULE *
Ignition #2 RED / YELLOW IGNITION SWITCH HARNESS
Ignition #3 N/A
Accessory WHITE/ BLUE IGNITION SWITCH HARNESS
Neutral Safety NOT GROUNDING TYPE - OEM SWITCH OPENS STARTER CIRCUIT
Brake Light GREEN/ YELLOW (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Light YELLOW (+) 20 PIN WHT CONN. IN PASS. KICK PANEL
Rear Window Defrost ORANGE (-) AT REAR WINDOW DEFOGGER SWITCH
* Engine Control Module Located Behind Glove Box. Note From Installer:A Transponder May Of Been Added To The 1999.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
