2003 Toyota Tacoma
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=20981
Printed Date: March 29, 2026 at 8:55 AM
Topic: 2003 Toyota Tacoma
Posted By: draasch
Subject: 2003 Toyota Tacoma
Date Posted: November 04, 2003 at 7:30 AM
I think I have posted this ?? before, but here we go again....
I'm going to re-wire the remote start tomorrow. I have the info:
Tach-black-at ign. coil
Ign.#2-blk/yllw-harness
The prob I have is that it wont always start on first time....I have put this off for a bit and now have the time to re-do it.
If I remember, I tried to use the tach less mode. I think that was my prob.
If you have some ideas, send this way......
Thks.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: 10nesne1
Date Posted: November 04, 2003 at 9:11 AM
you will need to connect the tech wire. The problem with Tech less is voltage sensing. The first start is to sens voltage and than it will start. Sometime, when it's cold and it will not start. Black is the tech wire.
good luck.
