Remote start on Grand Prix GTP
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=21153
Printed Date: May 15, 2026 at 5:12 PM
Topic: Remote start on Grand Prix GTP
Posted By: mustgkid
Subject: Remote start on Grand Prix GTP
Date Posted: November 08, 2003 at 9:01 AM
I has some work done on my car, and ever since then the security light blinks for 15 minutes and then turns off. Its the pk3 system.
I then bought a viper 550esp with remote start and seems I dont need the bypass 555g cause it starts without it. Does this mean my ignition system is going bad or what? Any advice will help me.. Thanks   Greg
Posted By: Haku
Date Posted: November 08, 2003 at 9:30 AM
More info... Year, ect...
Hak
Siemens Autostart
Posted By: mustgkid
Date Posted: November 08, 2003 at 10:18 AM
Posted By: mustgkid
Date Posted: November 08, 2003 at 10:21 AM
Posted By: krazypolishboy
Date Posted: November 10, 2003 at 12:53 AM
ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|red & RED / white     |+ |ignition harness            |
|          STARTER|yellow              |+ |ignition harness            |
|        IGNITION|pink               |+ |ignition harness            |
| SECOND IGNITION|white               |+ |ignition harness            |
|        ACCESSORY|orange              |+ |ignition harness            |
|       POWER LOCK|lt. blue            |- |driver kick panel           |
|     POWER UNLOCK|white               |- |driver kick panel           |
|       LOCK MOTOR|gray               |   |driver kick panel           |
|     UNLOCK MOTOR|tan                 |   |driver kick panel           |
|    DISARM DEFEAT|tan                 |   |passenger kick panel        |
| PARKING LIGHTS +|brown               |   |at switch                   |
|       HEADLIGHTS|yellow              |+ |at switch                   |
|     DOOR TRIGGER|tan and dark blue   |- |*1                          |
| DOME SUPERVISION|use door trigger    |   |                            |
| TRUNK/HATCH PIN|RED / black           |- |under rear deck             |
|TRNK/HTCH RELEASE|BLACK/ white        |+ |at switch                   |
|FCTRY ALRM DISARM|ORANGE / black        |- |driver kick panel           |
|       TACHOMETER|white               |   |pin 8, conn. 2 @ PCM *3     |
|      SPEED SENSE|dk.green            |4 |*2                          |
|       BRAKE WIRE|white               |+ |stop light switch           |
|     HORN TRIGGER|black               |- |steering column             |
|           WIPERS|gray               |+ |steering column             |
| LF WINDOW UP/DN|dk. blue - brown    |A |LF window motor in door     |
| RF WINDOW UP/DN|lt. blue - tan      |A |drivers kick panel          |
| LR WINDOW UP/DN|dk. green - purple |A |drivers kick panel          |
| RR WINDOW UP/DN|lt. green - purple |A |drivers kick panel          |
Notes:
NOTE: This vehicle is equipped with the pass-key III immobilizer. Use DEI part number 555G or 555U to bypass during remote start mode. *1 The tan is located in the drivers kick and catches only the drivers door. The dark/blue is located in the passenger kick panel and catches all other doors, must diode isolate these wires.   *2 Located at a 10 pin plug on the front of the drivers strut tower. There are two dk.green wires there, use the one in the corner of the plug. *3 The PCM (Powertrain Control Module) is in the air cleaner assembly.
