Matrix RS2 on ’01 Impala issues
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=21172
Printed Date: May 15, 2026 at 11:35 AM
Topic: Matrix RS2 on ’01 Impala issues
Posted By: Lord_Kaos
Subject: Matrix RS2 on ’01 Impala issues
Date Posted: November 08, 2003 at 4:56 PM
Only issues that I would like to resolve are that the installer (a friend) didn't hook up the lights to flash on arm/disarm and intermittantly upon remote starting the car the SES light comes on.
What would it take to wire up the parking lights to flash?
Is there something special that should have been done to prevent the remote start from throwing the SES intermittantly.
Thanks for any info
Shawn
Posted By: ricetech
Date Posted: November 08, 2003 at 5:55 PM
the parking lights are easy, just look up the alarm info in the vehicle info section of this site. then take the parking light wire from the alarm- its usually the white one- and splice into the parking light wire. its that easy. as for the ses light i have no clue.
Posted By: Velocity Motors
Date Posted: November 08, 2003 at 6:00 PM
The parking lights you require a relay and the use of the (-) parking light trigger wire ( WHITE at the BCM ). Wire the relay like this:
  • 85 : (-) parking light output from RS
  • 86: Constant 12 volt fused with a 20 amp fuse
  • 87 : GROUND
  • 30 : to WHITE wire (-) Switch Side
  • 87a: To White wire BCM side
Date Posted: November 08, 2003 at 6:11 PM
Thanks, that was exctly what i was looking for. I assume from reading around that that will probably take care of the SES problem too.
Date Posted: November 08, 2003 at 6:35 PM
Yes, that will saolve the warning light problem as well
Date Posted: November 14, 2003 at 6:18 PM
Can someone clue me in as to where the BCM is located in this car? I think i've found it, but i'm not sure. Everything else will be simple once i get that accomplished. Thanks
