PLDATA vs IPPO3
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=21262
Printed Date: May 14, 2026 at 6:26 AM
Topic: PLDATA vs IPPO3
Posted By: IRNOTSLOW
Subject: PLDATA vs IPPO3
Date Posted: November 10, 2003 at 6:40 PM
I have installed a RS in a 2002 Burb. I ask you guys opinion in the area of the Passlock II by-pass... Which is best?  and most reliable.  I have had two ("CUT wire and set dip switches" fail)
IPP03 type  (which is Learnable) https://www.12voltshop.com/proddetail.asp?prodid=IPP03&cat=1311&path=1,1311
This has a 6 wire hook up  GND, 12V, ING, starter, data from thin passlock wires, key sense
or PLDATA type https://www.12voltshop.com/proddetail.asp?prodid=PLDATA&cat=1311&path=1,1311
this has 4 wire hook-up  GND, 12V, data, NEG from remote start.
Thank you
irnotslow
Posted By: Haku
Date Posted: November 10, 2003 at 7:42 PM
I have used many PLDATA's and havent had a single failure.  Easy to use, hookup.  Of course, I havent installed an ipp03, so my opinion is somewhat one sided.
Hak
Siemens Autostart
