Disarm factory alarm?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=21265
Printed Date: May 14, 2026 at 6:20 AM
Topic: Disarm factory alarm?
Posted By: Tony7740
Subject: Disarm factory alarm?
Date Posted: November 10, 2003 at 7:12 PM
hi..i have a honda civic 00 2dr.   n planning to install the crimestopper 2015FM.  i need help on identify which wire to disarm factory alarm? i kno which wire come out from the crimstopper but not  sure where to connect it to the factory alarm?
im a newbie so please go eazy on me..thanks guys
TL
Posted By: Haku
Date Posted: November 10, 2003 at 7:48 PM
The factory alarm only arms and disarms with the factory remote.  So just dont use them.
At least thats the info I have.
Hak
Siemens Autostart
Posted By: Illuminatrix
Date Posted: November 11, 2003 at 12:43 PM
If your factory system has a strter kill you may run into problems.  Make sure you check it out.  If it is only a keyless entry as the above post says you can just ignore it.  First find out just what the factory system controls and let us know.
Cheers
Travis
Posted By: Velocity Motors
Date Posted: November 11, 2003 at 4:11 PM
Try to set off the OEM alarm and use your key in the driver's door to unlock the doors. If the alarm shuts off, then there will be a disarm wire in the door between the door and the car. If it does not, then Haku is correct in his post about arming and disarming ONLY with OEM remote FOB
Posted By: Tony7740
Date Posted: November 12, 2003 at 1:44 AM
its only the keyless entry so i guess i'll just ingnore it? or should i take out the fuse from it...under the driver dash
TL
Posted By: Tony7740
Date Posted: November 12, 2003 at 1:53 PM
sorry guys..my factory alarm does have the starter kill... and this is for the honda civic 00.   so wat's the best or eazy to disarm my factory alarm??
TL
