Honda Civic Clutch Bypass and lock?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=21309
Printed Date: May 13, 2026 at 4:00 PM
Topic: Honda Civic Clutch Bypass and lock?
Posted By: area51civic
Subject: Honda Civic Clutch Bypass and lock?
Date Posted: November 11, 2003 at 1:42 PM
I have an APS 996 alarm and need to know which wire coming off the clutch i need to plug into and which wire needs to go to that location.  I also have installed two DS2.1 door actuators into the vehicle.  when i connected the DLS port into the alarm and test it will only throw the actuators one direction.  Is it the relays or is it the wiring.
     Any help is greatly appreciated
                 Matt
Posted By: Velocity Motors
Date Posted: November 11, 2003 at 4:06 PM
Need more information. How did you wire the relays ? As far as the clutch goes use one of the two diagrams :
I believe the Honda uses a (+) clutch activation wire.
Date Posted: November 12, 2003 at 12:37 PM
The DLS socket is an omega.  The wiring diagram that comes with the socket says to connect the Brown and White wires to ground and then connect the purple wire to +12 the the Green and Blue wires to the matching wires coming off of the actuators.    I have it wire just as the manual says and i have checked the voltages coming from the brain and they are +12 and -12.  If this doesnt help let me know what other information might be of help.
  Thanks Matt
