doors wont unlock when door shut
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=21405
Printed Date: May 12, 2026 at 11:04 AM
Topic: doors wont unlock when door shut
Posted By: inacoma
Subject: doors wont unlock when door shut
Date Posted: November 12, 2003 at 10:32 PM
I have just installed a crimestopper informer car alarm/remote start. turning on and off the ignition will lock and unlock doors as planed. ...then if I keep the door opened after doing the above, then I can unlock and lock via the FOB. ...if I shut the door, then I can only LOCK the door and it won't UNLOCK. any help greatly apppreciated it's on a 96 toyota landcruiser that had a factory alarm kumar
Posted By: profuse007
Date Posted: November 12, 2003 at 11:25 PM
| POWER UNLOCK|blu/yel & blu/org *2|- |driver door harness in kick |
*2 Both wires must be used and diode isolated.
see if this helps
------------- Houston,TX
Posted By: inacoma
Date Posted: November 12, 2003 at 11:44 PM
currently i have it hooked up to: lock: GREEN/ red unlock: blue / YELLOW ...and I used he diodes that came with the kit. With the "white bar" on the diode on the alarm brain side. Soldered all connections. ...so what you are saying is there is one wire for lock, but TWO wires for UNLOCK. total 3 wires, 3 diodes. I have some extra diodes, but not sure what size to use. any recommondations? and do I have it correct that I need to find a third wire? thanks! kumar
Date Posted: November 13, 2003 at 12:00 AM
diodes(1n4001)-youre correct
yep, toyota have this safety thingy.... so you need both wire total of 3 wires for unlock and lock
goodluck!!!
Posted By: inacoma
Date Posted: November 13, 2003 at 4:19 AM
Profuse007, I looked all over for the blu/org wire, but did not find. So I took what you told me about a third wire and looked through my wiring diagrams and compared it to what was on the stock alarm plug. I found something called "door unlock detection SW Front LH". I said, what the heck, let's give it a try. IT WORKED. The color: Light Green (almost seafoam green). So add that to the cranium for future installs :) thanks again for all you help! k
Date Posted: November 13, 2003 at 9:38 AM
dude, you stayed up all night to finish this installation?
what a soldier.....
Posted By: inacoma
Date Posted: November 13, 2003 at 6:50 PM
actually i work nites and did it when i got off work. however, i have a new issue and may need to look for the wire you mentioned. but lets see what you say first. unlock and lock works till the cows come home EXCEPT...after this: remote start, don't open any doors, kill remote start from the remote, unlock then DOES NOT work. Kumar
Posted By: inacoma
Date Posted: November 14, 2003 at 4:53 PM
well...I found the Blue/orange wire and hooked it up. I still have the same problem I did as mentioned in m last post. Still can lock and unlock normally except after a remote start and stop from the remote...after that I can't unlock from the FOB> :(( is there any other wires or possibilities I should be looking at? thanks! Kumar
Posted By: defective
Date Posted: November 15, 2003 at 2:04 PM
ohh man you're in deep.....grin... i think i can help. According to "The Book" by Omega: "Some doorlock systems, however, require more than the 250ma. ground output that the security system's control module accomodates." use a relay to give the Unlock a better ground point. Hope this helps -------------
Posted By: inacoma
Date Posted: November 15, 2003 at 5:51 PM
well...i just closed up the truck. I went ahead and diasabled the auto lock after FOB start feature. that fixed my child lock problem. Next Time I open things back up, I'll try what you said. thanks! kumar
