using free channels on remote
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=21462
Printed Date: May 12, 2026 at 10:10 AM
Topic: using free channels on remote
Posted By: gbvette
Subject: using free channels on remote
Date Posted: November 14, 2003 at 8:26 AM
Hi everyone,
I hope I'm in the right section here.  I'm new to this remote and relay business so any help would be greatly appreciated.  Hope you don't mind a few dumb questions.
I have some free channels on a keyfob remote system installed in my car and want to use them to do some other things.
1 - Use 1 channel to activate the gas door release, currently it is operated by a switch.  How would I use a relay to do this?
2 - Use 1 channel simply to turn an accessory on or off?
3 - Use 1 channel to turn on a strobe light system and have it automatically shut off after about 60 seconds.  Can this be done?  How?
Thanks much,
Gary
Posted By: derek123
Date Posted: November 14, 2003 at 12:14 PM
>>> at the switch in question, find out what trigger ( signal, either + or - ) is sent when the button is pressed. Using a relay with this switch, your AUX out ( channel one, or what ever) would trigger the relay to send the same signal that  to the wire you tested.
ie. pressing the switch you see a wire goes +. So you set you relay up to send a
+ signal to the wire from your AUX out.
>>> generally same as above, but use a latching relay.
>>>  use a 528T pulse timer relay to activate the stobe, your AUX out trigger the relay.
To get in to more detail, tell us what polarioty the out puts from you alarm are, and what polarity the devices you wish to activate are triggered with.
Posted By: gbvette
Date Posted: November 14, 2003 at 9:28 PM
Thanks derek123!
All of the channels are negative outputs.   The gas door is -12V.  The strobes are +12V.
Thanks again!
