2003 honda acoord diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=21466
Printed Date: May 12, 2026 at 11:06 AM
Topic: 2003 honda acoord diagram
Posted By: twstdmr2
Subject: 2003 honda acoord diagram
Date Posted: November 14, 2003 at 1:08 PM
Does anyone have the diagram for this honda?????? Installing a remote start and already have 555u.
Posted By: twstdmr2
Date Posted: November 14, 2003 at 1:10 PM
sorry, its a 4 banger LX model
Posted By: profuse007
Date Posted: November 14, 2003 at 1:34 PM
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|white               |+ |ignition harness            |
|          STARTER|BLACK/ white        |+ |ignition harness            |
|        IGNITION|BLACK / YELLOW        |+ |ignition harness            |
|        ACCESSORY|BLACK/ red           |+ |ignition harness            |
| SECOND ACCESSORY|WHITE/ red           |+ |ignition harness            |
|       POWER LOCK|pink/black *1       |- |grn plug, L side of fusebox |
|     POWER UNLOCK|pink/blue *1        |- |grn plug, L side of fusebox |
|     UNLOCK MOTOR|YELLOW /GREEN        |5wi|grn plug, front of fusebox |
|    DISARM DEFEAT|yellow              |5wi|large wht plug above fusebox|
| PARKING LIGHTS +|RED / black           |   |large wht plug above fusebox|
| PARKING LIGHTS -|blk/red or blu/red |   |in steering column cover    |
|     DOOR TRIGGER|GREEN/ red           |- |grn 5 pin plg behind fusebox|
| DOME SUPERVISION|use door trigger    |   |                            |
| TRUNK/HATCH PIN|blue/black          |- |driver kick, harness to rear|
|        HOOD PIN|yellow/red          |- |hood pin switch in latch    |
|TRNK/HTCH RELEASE|YELLOW /GREEN        |+ |driver kick, harness to rear|
|FCTRY ALRM DISARM|white               |- |driver door module in door |
|       TACHOMETER|blue/red or blue    |   |ECM/PCM *2                  |
|       BRAKE WIRE|WHITE/ black        |+ |brake pedal switch          |
|     HORN TRIGGER|GREEN/ YELLOW        |- |steering column             |
Notes:
NOTE: This vehicle has an immobilizer system that needs to be bypassed when adding remote start. Use DEI part number 555U. *1 These wires will meter when using the passenger door lock switch. *2 The ECM/PCM is on the front of the transmission tunnel. The connectors are on the passenger side. On the 4 cylinder models the tach wire is in the white 31 pin connector E, pin 25. *3 The ECM/PCM is on the front of the transmission tunnel. The connectors are on the passenger side. On the 4 cylinder models the VSS wire is in the white 31 pin connector E, pin 26.
good luck!!!
Houston,TX
Posted By: twstdmr2
Date Posted: November 14, 2003 at 1:54 PM
gracias!!!! you da man
