GM Passlock, 03 malibu, pro-start 3300
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=21519
Printed Date: May 12, 2026 at 11:09 PM
Topic: GM Passlock, 03 malibu, pro-start 3300
Posted By: nyislanders
Subject: GM Passlock, 03 malibu, pro-start 3300
Date Posted: November 15, 2003 at 6:36 PM
I have a 03 malibu that is getting a pro-start 3300 installed.  The problem is that (according to them) that the by pass that I gave them for the passlock screwed up the car and put it into theft mode.  Now the car will not start!  They said that the pcm may have to be re-programmed to get the car out of theft mode.  Any advice that any of you guys can give me that I can pass along to get the car out of theft mode.  Because if they have to get this pcm re-programed then it may be a few days until I get my ride back.  Thanks
Posted By: Velocity Motors
Date Posted: November 15, 2003 at 6:37 PM
What Passlock bypass module did you use and can you remember the wires that you hooked up to it ?
Date Posted: November 15, 2003 at 6:40 PM
It was the bypass that commandocaralarms.com was selling (I can look it up), as for the wires, I am not the one hooking it up, I am just trying to help these guys out.
Date Posted: November 15, 2003 at 6:53 PM
the part #is (pass-mod) from commando car alarms.  Any guidance will be greatly appreciated
Posted By: jrilla
Date Posted: November 15, 2003 at 11:49 PM
Well its not the bypass's failt, they were the ones who screwed it up, they should fix it, or pay for it. This is why I dont think it is a good idea to buy something and have someone else install it.
J Rilla
Owner/Installer
Date Posted: November 16, 2003 at 7:50 AM
Well expressed J Rilla. I agree, but the problem is still there. Until the dealership can scan the car and see what's going on with it, it will be a waiting game.
Posted By: ck auto
Date Posted: November 16, 2003 at 12:22 PM
did you try leaveing key on for at least 10 min you may have to do this for one hour if that doesn't work there is a procedure to reset pass 2 i can't remember it but maybe somebody else does
kirk
