Ultra Start 4500 '91 Toyota Previa
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=21588
Printed Date: May 13, 2026 at 9:03 PM
Topic: Ultra Start 4500 '91 Toyota Previa
Posted By: AUTOCAD
Subject: Ultra Start 4500 '91 Toyota Previa
Date Posted: November 17, 2003 at 8:57 AM
Hi all
I am installing Ultra Start 4500 on (Start/Alarm) a 91 Toyota PreviaI was wondering it is neccessary to hook up the two wires for Door trigger (+/-)By the way what do these do? what is the affect if you don't hook up?Also with passenger unlock (pink wire from unit) where do I connect this too.
AutoCad
AUTOCAD
Posted By: vaderfop
Date Posted: November 17, 2003 at 11:12 AM
The passenger door unlock wire should be for, if you need a second pulse to unlock all you doors, i.e. if you can unlock you driver's door seperate from the rest of your doors you then need this wire to be connected so that all your doors will unlock with your alarm disarm.
The door trigger wire is for if someone opens one of your doors the alarm will be triggered. You do not need both of the wires. For your car you only need the (-) negitive trigger. It should be a RED / yellow wire under the left side of your dash.
Remember check all your wires with a DMM!
Posted By: AUTOCAD
Date Posted: November 26, 2003 at 2:19 PM
AUTOCAD wrote:
Hi all
I am installing Ultra Start 4500 on (Start/Alarm) a 91 Toyota Previa I was wondering it is neccessary to hook up the two wires for Door trigger () By the way what do these do? what is the affect if you don't hook up? Also with passenger unlock (pink wire from unit) where do I connect this too.
AutoCad
Hi all
Please help! (Utra start 4500)
I can't figure out why the my vehicle sometime start by itself.
First of all, the temperature sensor is not installed and the Timer Mode is not set to on
I have tried to disable the Timer Mode many times (if it is on) but that didn't fix the problem
I came home the other day and found the van running, so turn it off by stepping on the brake
According to manual, the Timer Mode will automatically disable itself after 24 hours
So I don't what cause it to start.
Thanks all
I
AUTOCAD
