2004 tacoma alarm wiring diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=21636
Printed Date: May 14, 2026 at 1:02 PM
Topic: 2004 tacoma alarm wiring diagram
Posted By: speedtriple
Subject: 2004 tacoma alarm wiring diagram
Date Posted: November 18, 2003 at 7:23 AM
i have a 2004 toyota tacoma 2WD and need the wiring diagram to install an alarm.
thanks
Posted By: mazdatruckin
Date Posted: November 18, 2003 at 8:19 AM
12volts  white (40A), wht/red (30A)   +   ignition harness
Starter  black   +   ignition harness
Ignition  BLACK/ red   +   ignition harness
Second Ignition  BLACK / YELLOW   +   ignition harness
Accessory  blue/red   +   ignition harness
Keysense  lt. GREEN/ red   -   ignition harness
Notes: Using the status output from the remote start to trigger this wire will disarm the alarm without unlocking the doors.
Power Lock  gray   -   front of fuse box, 22 pin plug
Notes: These wires will test only by operating the key in the passenger door lock cylinder, not the rocker switch on the door.
Power Unlock  purple   -   front of fuse box, 22 pin plug
Lock Motor  blue/white   5wi  DKP, 12 pin plug in pin 10
Unlock Motor  blue   5wi  DKP, 12 pin plug in pin 11
Parking Lights+  green   +   back of fuse box, 12 pin plug
Parking Lights-  PURPLE / red, red, or yellow   -   front of fuse box, 22 pin plug
Hazards  same as turn signals
Turn Signal(L)  green   +   steering column
Turn Signal(R)  GREEN / WHITE   +   steering column
Reverse Light  RED / black   +   under driver seat, 13 pin plug
Door Trigger  see notes   -   front of fuse box, 22 pin plug
Notes: The driver door trigger is green, the front passenger door is GREEN / WHITE, and the rear doors is YELLOW /GREEN. Use all three wires and diode isolate each.
Dome Supervision  comes on with unlock
Factory Alarm Arm  arms with lock
Factory Alarm Disarm  disarms with unlock
Disarm No Unlock  use key sense wire
Tachometer  NOT blk/yel, blk/red, or brn   ac   any ignition coil
Notes: Vehicles with a tachometer in the instrument cluster can also use a lt. GREEN/ black wire for tach. On the 4 cyl it is at the data link connector to the right of the steering column. On the V6 it is at the igniter on the passenger fender, below the air filter box.
Brake Wire  GREEN / WHITE   +   brake pedal switch
Parking Brake  GREEN / WHITE   -   parking brake switch
Horn Trigger  GREEN/ red   -   steering column
LF Window up/dn  blue / YELLOW - blue      A   driver window switch
RF Window up/dn  RED / black - RED / green   A   driver kick, 12 pin plug
LR Window up/dn  RED / blue - blue/black   A   driver kick, 13 pin plug
RR Window up/dn  yellow - lt. green      A   driver kick, 13 pin plug
Posted By: johnmsi
Date Posted: December 17, 2003 at 11:03 PM
Posted By: Javelin3o4
Date Posted: December 18, 2003 at 3:03 AM
I got lucky on one of these the other day, i pulled the lower dash of and it had already been prewired for an alarm, even the 3 door trigger wires were already diode isolated.
