Passlock II bypass question
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=21838
Printed Date: March 28, 2026 at 7:39 PM
Topic: Passlock II bypass question
Posted By: Carbuff5
Subject: Passlock II bypass question
Date Posted: November 23, 2003 at 4:37 PM
Hi, I'm installing aa alarm bypass module by DesignTech (dip-switch model). All resistance references are in k-ohms and the measured resistance on the passlock wire is 8.47Meg-ohms. Has anyone encountered such a difference or have any suggestions.
Posted By: ck auto
Date Posted: November 23, 2003 at 4:42 PM
hi i would suggest testing again reverser leads and see if you get same resistance or close to it.  I would also suggest using a no cut style passlock module like the pl 2003 or pl data if the dip switch type fails the car will not start with the key seen it happen a few times i use the no cuts and haven't had a problem and they are easy to program no resistance reading to take just a trimpot to turn
good luck
kirk
Posted By: sroth140
Date Posted: November 24, 2003 at 2:27 AM
go buy a 555L.  i hate the dipswitches.
