ProStart CT-5060
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=21889
Printed Date: March 28, 2026 at 9:04 PM
Topic: ProStart CT-5060
Posted By: LMcFester
Subject: ProStart CT-5060
Date Posted: November 24, 2003 at 3:13 PM
My second last resort - next is pulling out and starting anew...
I just installed a Prostart CT-5060 in my Protege - manual transmission.  Powered the unit up and programmed remotes and programmed the tach.  Tried it out, remote started perfectly.  Once...
Trouble is, I cannot get the unit into ready mode again.  Have followed the procedure for getting into ready mode accurately, but the LED does not flash after pressing the remote buttons before pulling the key out.
Any ideas out there.
P.S.  I've reset and reprogrammed the unit two times now...
Thanks.
Posted By: mxxmikexx
Date Posted: November 24, 2003 at 8:01 PM
Ready mode? what are you trying to do? im familiar with prostart pieces, but i dont know what "ready mode" is?
Mike Battaglia
Specialized Car Audio
Bensenville IL 60106
Posted By: ck auto
Date Posted: November 24, 2003 at 8:12 PM
hi check your hood pin to make sure you don't have a ground on it at the module its the grey wire ive had them rs a couple of times thenn the hood pin goes out of wack strange. good luck pretend to drive the car eg.  release park brake rev motor sometimes they like to see the tach signal change befrore they will go into ready mode also make sure when you learned tach signal it was at regular idle. engine warmed up also it wont sequence if it see's a tach signal  that is higher than what it learned at.
kirk
Date Posted: November 25, 2003 at 10:41 AM
Thanks all.
...Checked all the wires again - turns out there was a poor connection for the parking brake (those damn ground connections always give me trouble).  Working again perfectly.
Ready mode is ProStart's term for making sure the manual transmission car is ready for a remote start - i.e. making sure it is not in gear and the parking brake is set.  Page 12 of the ProStart CT-5060 manual (https://206.47.191.115/prostart/guides/CT-5060_IG_EN_H100S100v103b104.pdf) or see the CT-5060 installation guide at https://www.autostart.ca/prostart/mainSupport.html.
Incidentally, I called ProStart / AutoStart's help line.  Very prompt return call...
Thanks for the help.
Next project is installing a RS unit in a 2003 Caravan...
Posted By: summersp
Date Posted: January 26, 2004 at 3:58 PM
My CT 5060 wont go into "Ready MODE" worked once. now it wont. anyoe know what to do? ssummerfild@execulink.com
