Wiring Diagrams Acura MDX SUV 2001
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=21915
Printed Date: March 29, 2026 at 1:33 AM
Topic: Wiring Diagrams Acura MDX SUV 2001
Posted By: nguyen
Subject: Wiring Diagrams Acura MDX SUV 2001
Date Posted: November 25, 2003 at 1:21 AM
May some one help me a Diagram of Acura MDX SUV 2001 for install remote car stater and alarm.
Nguyen
Posted By: draasch
Date Posted: November 25, 2003 at 5:57 AM
Make:   Acura
Model: MDX
Year:    2001-02
This Database Was Last Updated On:    6/9/2003
Index #: 5671
Alarm
Constant 12 volts WHITE IGNITION SWITCH HARNESS
Ignition 12 volts BLACK / YELLOW IGNITION SWITCH HARNESS
Starter BLACK/ WHITE * IGNITION SWITCH HARNESS
Dome Light BLACK/ WHITE (-) AT SWITCH IN CENTER OF DASH
Trunk Pin Switch ORANGE (-) 10P GREY CONN DRIVER KICK BEHIND DASH
Parking Lamp RED / BLACK (+) ** AT TAILLIGHT RELAY UNDER DRIVER DASH
Power Lock BLACK/ WHITE AT DRIVER DOOR MULTIPLEX #201
Power Unlock GREEN/ RED CONTROL UNIT 20P LT BLUE CONNECTOR
#201- See Negitive Door Lock Circuit Diagram * Installing A Starter Kill Relay At The Ignition Switch Harness Before The Starter Wire Enters The Driver Side Fuse Block May Cause A "Check Engine" Light To Come On. Starter Wire Should Be Accessed After Fuse Block. ** Relay Is Center Of 3 Relays
Remote Start
Tach Signal GREEN/ BLUE TEST CONN LEFT REAR OF ENGINE COMP**
Ignition #2 YELLOW IGNITION SWITCH HARNESS * #239
Ignition #3
Accessory WHITE/ BLACK IGNITION SWITCH HARNESS
Neutral Safety NON GROUNDING TYPE
Brake Light WHITE/ BLACK (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Light WHITE (-) GRN 20P CONN IN DRIVER FUSE/RELAY BOX
Rear Window Defrost BROWN / YELLOW (-) 16 Pin GREY CONN @ CLIMATE CONTROL
#239-See Immobilizer Bypass Circuit Diagram * DB-PKH2 Is Availible For Transponder Bypass W/No Additional Key Required ** Alt Tach Wire- GREEN/ BLUE In GREY 32 Pin CONN At PCM Under Center Of Dash
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: nguyen
Date Posted: November 25, 2003 at 8:32 AM
Thank you very much
Nguyen
Posted By: nguyen
Date Posted: November 25, 2003 at 9:08 AM
Dear Sir,
Where I can get DB-PKH2 Transponder Bypass W/No Additional Key Required for Acura MDX 2001, what is color wires of SYNCHRO, DATA WIRES OF THIS CAR?
Nguyen
Posted By: draasch
Date Posted: November 25, 2003 at 2:34 PM
im not sure i follow your ??
are you talking about the tach wire??
i will send u a PM when i get the info on the bypass kit
Good Luck
David
Ace Security
813-376-9778
Tampa
Posted By: nguyen
Date Posted: November 25, 2003 at 7:44 PM
Dear David,
when install PKH2 transponder bypass model (or Dei 555H)we need to known 3 wires on Acura/ honda immobilizer module: Ground wire (BROWN / black), Synchro wire(Accord Blue), Data wire(Accord red). I did not known what is color of these wires on Acura MDX 2003?
Anthony Nguyen
Posted By: profuse007
Date Posted: November 25, 2003 at 8:07 PM
heres the manual for the 555h
Houston,TX
Posted By: nguyen
Date Posted: December 13, 2003 at 1:13 AM
Thanks for your help,
Here is true wiring I get in Acura MDX 2001 which has some different wiring diagram David given above.
Power lock: BLACK/ orange at passenger Mux Unit
Power unlock: blue/orange at passenger Mux Unit
Fctry alarm arm: blue/white at driver lock key cylinder
Fctry alarm disarm: BLACK/ red to blue at driver lock key cylinder
Anthony Nguyen
