96 Corsica door trigger
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=21944
Printed Date: April 20, 2026 at 2:25 AM
Topic: 96 Corsica door trigger
Posted By: padawan
Subject: 96 Corsica door trigger
Date Posted: November 25, 2003 at 1:54 PM
Trying to install an alarm on a 96 Corsica, can't find the dang door trigger wire, my info says it's white (-) located at convienence center (where is the convienence center anyway?)...but I tested so many wires to the left of the column and can't locate it...
Also, has anyone ever worked on this vehicle, if so, how on earth do you get the kick panel cover off? And where can I get a wire through the firewall on this car? Thanx guys.
Posted By: draasch
Date Posted: November 25, 2003 at 2:27 PM
hope this helps...
Make:   Chevrolet
Model: Corsica
Year:    1996
This Database Was Last Updated On:    6/9/2003
Index #: 2573
Alarm
Constant 12 volts RED (2) IGNITION SWITCH HARNESS
Ignition 12 volts PINK IGNIITON SWITCH HARNESS
Starter YELLOW IGNITION SWITCH HARNESS
Dome Light WHITE (-) AT COURTESY LIGHT *
Trunk Pin Switch N/A
Parking Lamp BROWN (+) AT HEADLIGHT SWITCH **
Power Lock L BLUE DRIVER KICK #202
Power Unlock WHITE PANEL
* Optional Door Trigger: L GREEN/ BLACK (-) Covers Driver Door, L BLUE (-) Covers Passenger Door & L BLUE/BLACK (-) Covers Both Rear Doors At Convenience Center Module Located Behind Driver Dash. Diode Isolation Needed: Cathode (Band) Side Of Diode Faces OEM Wires. ** BROWN (+) Wire Also Located In Driver Kick Panel. #202- See Positive Pulse Door Lock Diagram.
if you dont have screws holding the KP on. then there may be plastic clips
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
