99 Explorer door locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=22070
Printed Date: May 01, 2026 at 9:18 PM
Topic: 99 Explorer door locks
Posted By: gpowen
Subject: 99 Explorer door locks
Date Posted: November 28, 2003 at 3:44 PM
Do I need any relay's or diodes to get my doors to work? My remote start has (+/-)output for the doors.
Also what color are the wires are the + and - inputs?
Posted By: mobiletoys2002
Date Posted: November 28, 2003 at 11:18 PM
pink / YELLOW is your lock wire and pink/green is unlock these wires are negative trigger door locks.
You are going to use the outputs of the alarm for negative locks and no relays should be required.
The door lock wires mentioned above are in the driver kick panel and are small guge wires they may also be at the factory keyless entry unit. good luck
