1997 Sable door locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=22269
Printed Date: May 04, 2026 at 11:00 AM
Topic: 1997 Sable door locks
Posted By: toyvet1
Subject: 1997 Sable door locks
Date Posted: December 02, 2003 at 10:02 PM
My wife just got a 1997 Sable with 20,000 miles. The factory door remotes do not work. The power locks work fine. When I picked up the car it had a dead battery, no light or anything. Do the remotes need to be reprogramed or something. I would like to get this resolved before I install a remote starter.
Posted By: diabloed
Date Posted: December 03, 2003 at 12:25 AM
there should be a programming guide in the owners manual. not 100% sure what it is of the top of my head.
Posted By: chriswallace187
Date Posted: December 03, 2003 at 12:44 AM
This is going to sound stupid, but have you changed the batteries in the factory remote? If that's allright, check with your dealer on programming...it's generally not so complicated that you'll pay out the ass for it.
Posted By: Scott35
Date Posted: December 03, 2003 at 7:59 PM
Cycle ignition from off to run 5 times within 10 secs, ending in run. All doors will lock then unlock to confirm programming mode. Press any button on 1st remote, door locks will cycle to confirm programming, press any button on 2nd remote, turn ignition to off. Locks will again cylce to indicate end of programming mode.
------------- Tacomacrew
Posted By: toyvet1
Date Posted: December 04, 2003 at 5:52 AM
Worked like a charm thanks for the help...
