1998 jeep wiring diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=22366
Printed Date: May 04, 2026 at 9:26 AM
Topic: 1998 jeep wiring diagram
Posted By: greenville auto
Subject: 1998 jeep wiring diagram
Date Posted: December 04, 2003 at 8:33 PM
i am installing a audiovox remote starter in a 1998 jeep grand cherokee and i also purchased a door lock module   i need a wiring diagram for this vehicle if anyone can help thank you
chris green
Posted By: mainormoscoso
Date Posted: December 04, 2003 at 9:31 PM
 JEEP GRAND CHEROKEE 97-98
WIRE COLORSLOCATION
12 VOLTS CONSTANT
RED / WHITE ( 2 )
IGNITION SWITCH HARNESS
IGNITION 1DK.  BLUE/GRAYIGNITION SWITCH HARNESS
IGNITION 2RED / BLACKIGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 1BLACK/ ORANGEIGNITION SWITCH HARNESS
STARTERYELLOWIGNITION SWITCH HARNESS
PARKING LIGHTSDK. BLUE/RED ( + )@ HEADLIGHT SWITCH
DOMELIGHTYELLOW  ( - )@ COURTESY LIGHT
PWR DOOR LOCKORANGE / VIOLETDRIVER DOOR SWITCH *1
PWR DOOR UNLOCKPINK/BLACK   (5 wire) *SEE DIAGRAM*
TRUNK RELEASEORANGE / BROWN@ RELEASE SWITCH
TACH SENSORGRAY/WHITE@ PCM  *2
BRAKE
WHITE/ TAN  ( + )@ SWITCH ABOVE BRAKE PEDAL
HORN
GRAY/ORANGE ( - )
@ STEERING COLUMN
FACTORY DISARM
VIOLET / YELLOW ( - )
DOOR HARNESS in DRIVER KICK PANEL
NOTES:
*1 - Use ORANGE / VIOLET for lock and PINK/BLACK for unlock at the drivers door switch to operate the drivers door lock. Use BLACK/ WHITE for the lock and PINK/BLACK for unlock at the passenger front door switch to unlock all passenger doors. It is required to interface in each door even if the vehicle is equipped with keyless entry.
*2 - The PCM (Power Control Module) is located high on the passenger side firewall.
