2003 Dodge Ram Auto Unlock
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=22412
Printed Date: April 19, 2026 at 10:00 AM
Topic: 2003 Dodge Ram Auto Unlock
Posted By: tanman
Subject: 2003 Dodge Ram Auto Unlock
Date Posted: December 05, 2003 at 7:53 PM
I have successfully installed a remote start and Remote Keyless Entry system on a 2003 Dodge Ram 1500.  I am wanting to add another relay to auto unlock doors when automatic transmission is placed in Park position.  Can anyone tell me the correct wire and polarity to tap into for my relay circuit?  It would need to be wired in such a way that it would generate a single pulse, so the relay would not always be activated...any ideas?
Thanks!
Jeff Sepulveda
Posted By: daniel2002p
Date Posted: December 05, 2003 at 8:44 PM
you neee to find the wire that shows 12v when the truck is in park (behind intrument cluster) and get a pulsing relay.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
Posted By: Supertom
Date Posted: December 06, 2003 at 10:03 AM
What diagram did you use for the 2003 Dodge? Is it the same as the 2002? Does this truck have a anti-theft system?
Posted By: whiteshack
Date Posted: December 06, 2003 at 4:47 PM
what you can try
12v brake trigger to 85
86 to park wire behind cluster invert to neg.
30 single pulse generator output
87 to neg of alm unlock to door locks
this circuit is active when brake and park wire is used. good luck
you will also need to trigger the single pulse with the brake wire and park wire also
mecp certified installer
