01 ford excursion door locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=22451
Printed Date: March 07, 2026 at 12:29 AM
Topic: 01 ford excursion door locks
Posted By: streetstyle
Subject: 01 ford excursion door locks
Date Posted: December 06, 2003 at 5:53 PM
does anyone know where to grab doorlock wires on this vehicle? audiovox tech says pink yellow and pink green in drivers kick but they are not there
Posted By: auex
Date Posted: December 06, 2003 at 6:41 PM
Driver's door boot or high in the kick.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: misterjimbo
Date Posted: December 06, 2003 at 8:26 PM
in the kick there are black white and white black wires two of each ant they are taped together. this is also true in the super duty pickups. they changed half way through the production year
Posted By: seniorswankey
Date Posted: December 07, 2003 at 1:12 PM
they are there, im 100%. ive done this vehicle 100 times over. the yellow and green colors on the wire are very faint and easy to miss, but they are there. sometimes you can find them in the passanger kick panel as well. give that a shot.
Posted By: mxxmikexx
Date Posted: December 08, 2003 at 3:44 PM
i wound up grabbing them in a harness to the right of the steering column wrapped in black tape, i cut it open and grabbed them there.
------------- Mike Battaglia
Specialized Car Audio
Bensenville IL 60106
