1990 dodge caravan rear hatch pin
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=22468
Printed Date: March 07, 2026 at 7:56 AM
Topic: 1990 dodge caravan rear hatch pin
Posted By: maroda
Subject: 1990 dodge caravan rear hatch pin
Date Posted: December 06, 2003 at 10:37 PM
I have a 1990 dodge caravn trying to hookup keyless entry and hatch pin for dome light.
Anyone with any ideal how?
maroda
Posted By: Geeque
Date Posted: December 24, 2003 at 9:38 AM
You can tap into the domelight circuit for the hatch. See if this helps:
1990 DODGE CARAVAN MINIVAN   SecurityBattery    RED +   (+)   IGNITION SWITCH HARNESSIgnition   DK.BLU   (+)   IGNITION SWITCH HARNESSStarter01   YEL +    (+)   IGNITION SWITCH HARNESSAllDoorTrigger   YEL (-)   (-)    OR YEL/WHT (-)  DRIVER'S PIN SWITCHTrunkTrigger   TAN/BLK(-)   (-)    DRIVER KICK PANELHoodTrigger    N/AFactoryAlarmDisarm    N/AParkingLights    BLK/YEL    (+)   AT LIGHT SWITCHRemote StartBattery    RED +   (+)   IGNITION SWITCH HARNESSIgnition   DK.BLU   (+)   IGNITION SWITCH HARNESSIgnition02   +   IGNITION SWITCH HARNESSIgnition03   +Accessory01   BLK/RED +   (+)   IGNITION SWITCH HARNESSAccessory02    +Starter01   YEL +    (+)   IGNITION SWITCH HARNESSAntiTheftSystem   NONENeutralSafety    BRN/YEL   (-)    AT SWITCHTach   BLK/GRY (-)    (-)    AT COILSpeedSense   WHT/ORG    (AC)   TRANSMISSION ParkingLights    BLK/YEL    (+)   AT LIGHT SWITCHBrakeLights   WHT    (+)   AT BRAKE SWITCH ReverseLights   VIO/BLK    (+)   AT SWITCHHorn   BLK/RED(-)   STEERING COLUMN HARNESSDoorlocks / WindowPowerUnLock    PNK   (REV)   REVERSE POLARITYPowerLock    ORN    (REV)   DRIVER'S KICK PANEL OR BEHIND DRV SPEAKEConvenienceHeadLights    LT GRN(+)   (+)   HEADLIGHT SWITCHTrunkRelease  LT GRN/BLK (+) DRVR'SKICK +12V RELAY OUTPUT TO WIRE***
Gary Kline
MECP Master Technician
