Omega RS-7K
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=22471
Printed Date: March 07, 2026 at 11:58 AM
Topic: Omega RS-7K
Posted By: romadoor
Subject: Omega RS-7K
Date Posted: December 06, 2003 at 10:52 PM
I installed an Omega RS-7K and used the Smart Sense option. I need to program a longer cranking time for colder weather. Removing the jumper does not help. Anyone know how to program a longer crank time? Thanks, Romadoor
Posted By: fordfan
Date Posted: December 07, 2003 at 12:59 PM
What jumper are you talking about? If you need to change the cranking time you need to go into program mode and change it there. I don`t have a manual here right now I will get one and tell you how to do it if you don`t have a manual yourself.
Posted By: romadoor
Date Posted: December 07, 2003 at 9:19 PM
Thanks FordFan,
There are 4 jumpers inside the cover. I have a manual but it does not explain how to to enter program mode and change any settings, only how to program a new remote. I would appreciate any instructions you have on how to change cranking times.
Thanks, Romadoor
Posted By: fordfan
Date Posted: December 08, 2003 at 3:40 PM
I just looked at the manual and it says you need to power down the unit. Either disconnect your battery or pull the fuses going to the r/s unit. Hope this helps it`s all I could find.
Posted By: fordfan
Date Posted: December 08, 2003 at 3:42 PM
By the way it`s jumper #4, remove it for longer crank times.
Posted By: romadoor
Date Posted: December 08, 2003 at 10:48 PM
Hey,
Thanks FordFan, That solved the problem!
Thanks for your time.
Thanks romadoor@aol.com
