95 jeep grand cherokee RS/alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=22515
Printed Date: April 18, 2026 at 6:35 AM
Topic: 95 jeep grand cherokee RS/alarm
Posted By: vaderfop
Subject: 95 jeep grand cherokee RS/alarm
Date Posted: December 07, 2003 at 9:53 PM
Installed a RS/alarm in this a few weeks ago and everything worked fine, howver now, it will not stay remote started. It starts and runs for a couple seconds then turns off, kind of like a transponder problem, except jeep did not but transponder in these cars. I know this person's key does not have a transponder anyway since he got the key cut at walmart and it works just fine.
Any one got any ideas?
------------- Remember check all your wires with a DMM!
Posted By: Cityauto
Date Posted: December 07, 2003 at 10:08 PM
sounds like a tach issue, or if your on voltage, its not seeing the alternator firing up. best to use an injector these days for your tach signal, especially if your using DEI product
------------- Joe Zero
City Auto Security
Quincy Ma 02169
Posted By: vaderfop
Date Posted: December 07, 2003 at 10:32 PM
hrm i think i got the tach from one of the injectors...if i graped the wrong wire could that cause that, ut still look like a tach for progaming?
Posted By: sroth140
Date Posted: December 08, 2003 at 1:51 AM
grab the grey/blue wire at the PCM, the Powertrain control module located on left inner fender behind headlight. test for ac and verify with a tap on the throttle.
Posted By: Velocity Motors
Date Posted: December 08, 2003 at 1:42 PM
The injector wire you used should have been one of the uncommon colored ones.
------------- Jeff
