F250 Diesel remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=22611
Printed Date: April 04, 2026 at 7:35 AM
Topic: F250 Diesel remote start
Posted By: S Balderson
Subject: F250 Diesel remote start
Date Posted: December 04, 2003 at 6:46 PM
Could anyone please provide me with the install sheet from DEI for a 03 Ford Super Duty  deisel. Also, if I need to use diodes, or any other relays could you please let me know. I am installing a Valet 554R
sbalderson
Date Posted: December 09, 2003 at 4:00 PM
I am looking for DirectFax document 1091 on diesel wait light information.
sbalderson
Posted By: zargon
Date Posted: December 09, 2003 at 6:05 PM
I'll tell you what we've been doing with diesels this year, we are using a pulse timer and timing it 5 seconds longer than the wait to start light stays on.This is what dei is having us do with chryslers, hey i just looked at 1091 and it says the same thing to use part number 528 pulse timer, there you go.
zargon ruler of estranorth
Posted By: kenmci
Date Posted: December 09, 2003 at 7:05 PM
I just recently did one of these remote starts and many of the newer alarms have a standard wait to start built in.  The alarm I used was a Black Widow and it had a build in 15 second timer if you don't hook up the wait to start wire.  DEI is a better alarm so I would assume they have a built in wait to start.  Check the programming information to see if you can set up the RS for desiel and see if it has a wait to start timer built in.  Much easier.
Date Posted: December 22, 2003 at 9:20 PM
I am looking for the door trigger wires colors and location?
sbalderson
Posted By: misterjimbo
Date Posted: December 22, 2003 at 9:52 PM
all door trigger is black blue 12v in harness in front of the b pillar .take off the step plate and you will see two harnesses. one from the front of the car and another coming from the b pillar, the trigger is in the one comming from the b pillar
