prostart ct 3100 remote starter diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=22615
Printed Date: April 04, 2026 at 6:17 PM
Topic: prostart ct 3100 remote starter diagram
Posted By: Falcon 1
Subject: prostart ct 3100 remote starter diagram
Date Posted: December 09, 2003 at 5:11 PM
Hi does anyone have schematics for a prostart ct 3100 remote starter. Thanks
Do it right the first time, only a doctor can bury his mistakes.
Posted By: sparkie
Date Posted: December 09, 2003 at 6:41 PM
The two thick red wires are the main power in.The thick yellow wire is the ignition. The thick orange wire is the accessory wire(heater). The purple wire is the starter wire. If it has a thick green wire that is the selectable onboard high current relay. You can select it for 2nd ignition, acc., or starter.The black wire is ground. The smaller orange wire is for the switched side of the brake switch. The thinner yellow wire is the + parking lights. The thinner purple wire is for tach and the grey wire is for the hood pin. The thin green wire is negative unlock, the brown is negative lock. The blue is the second channel (-). If there is a WHITE/ brown this is the rearm wire. The WHITE/ green is the disarm wire. The solid white wire is usually the negative out when running wire. If this doesn't match I'm sorry as I am doing it from memory.
sparky
Posted By: ck auto
Date Posted: December 09, 2003 at 7:00 PM
hi if you go to https://206.47.191.115/prostart.nsf/en/Support2 you can download a install manual from there site
good luck
kirk
Posted By: Falcon 1
Date Posted: December 09, 2003 at 8:14 PM
Thanks very much for the info and link.posted_image
