1999 GMC Van Rmt start wont stay running
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=22626
Printed Date: April 05, 2026 at 7:08 AM
Topic: 1999 GMC Van Rmt start wont stay running
Posted By: acoccoluto
Subject: 1999 GMC Van Rmt start wont stay running
Date Posted: December 09, 2003 at 7:53 PM
Hi, I am trying to wrap up a remote start installation on a 1999 GMC Savana.  Everything seems to function properly and the engine will start buut shut off right away.  If I click the Starter with the key and leave the key in the on position the remote unit will start without a problem.  I seem to remember running into a similar problem with a suburban but cannot seem to remember the solution.  Is there some sort of aux signal from the switch aside from B+, Ign 1,2 &3, and ACC?
Please help if you know the answer..
Posted By: ck auto
Date Posted: December 09, 2003 at 8:41 PM
hi your van has passlock II use pl2003 to bypass during rs
good luck
kirk
Posted By: Aston42560
Date Posted: December 09, 2003 at 9:56 PM
i would use the dei 555l passlock bypass to over ride the keycylinder security
Posted By: daniel2002p
Date Posted: December 10, 2003 at 10:01 AM
DEI 555Lis the best for them
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
Date Posted: December 10, 2003 at 11:03 AM
Where can a guy find one of these DEI 555L units?
Thanks.
Allan
Posted By: boomer_106
Date Posted: December 10, 2003 at 11:58 AM
The following link may help you. I hope this doesnt violate any rules if so please let me know.     https://www.google.com/search?hl=en&ie=UTF-8&oe=UTF-8&q=DEI+555L   Good luck
