How to Increase Crank Time on Viper Start?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=22658
Printed Date: April 05, 2026 at 9:55 AM
Topic: How to Increase Crank Time on Viper Start?
Posted By: electgeek
Subject: How to Increase Crank Time on Viper Start?
Date Posted: December 10, 2003 at 2:19 PM
Ok over a year ago I had an installer put in a remote start module on my old Viper alarm system.  The viper alarm system was installed back in 1993.  It is a two button (I believe I asked the installer if it was a 3-channel, where you hold down buttons I and II to transmit channel III and he said no- it is only 2) non rolling colde system (if you open the remote, you can see that the code is programmed by breaking wire jumpers).  I know this is not really important but I guess it might help an expert out there to identify the particular alarm system model I have.
Anyway he put in a module which I believe was made by Viper to work with this system.  When I hold down button II for a few seconds the remote starter activates.
Last winter I noticed that in very cold weather, the remote starter would crank for a second or two and then stop, and the car had not yet turned over, so it was not running.  It does this three times and gives up.
This only happens in very cold weather (approximately below 25 degrees F)
FYI the car is a 92 Honda accord 4door automatic with fuel injection.
The installer charged me $70 to 'resolder all the wires' (*) and it didn't work.  However he said (1) the module was under warntee and the problem was covered even if it took a while to show itself and (2) he believed he could increase the crank time.
(*) Yes, I know how bogus this sounds. I assume he did do some trouble shooting. The original Viper alarm was not installed by him so I am assuming that's why he charged me the labor.
So my question is- does anyone here know how to increase the crank time on the Viper remote start module??
There is a slight chance I have the box that the remote start module came in, which might have the model number on it (I dont think he gave me the instructions).  Also I have the original remotes, so maybe at least the model of the alarm part can be determined?
The directed.com website is running very slowly right now so I am not finding any useful info there.
Thanks to anyone who can help out!!
Posted By: lophix
Date Posted: December 10, 2003 at 2:26 PM
i'm not sure if it depends on the model of remote start you have, but for starters, you CAN increase the crank time. Search DEI's website for remote start manuals and the programming codes of most of their remote starts and confirm that they are all the same.....or close at least. Then follow the programming sequence which will require you to enter programming mode by pushing the valet button. www.directed.com
goodluck.
xmfan
Posted By: profuse007
Date Posted: December 10, 2003 at 6:19 PM
if youre using tach sense, then increasin crankin time is useless. if you use volt sense, then you may reprogram it...
Houston,TX
Posted By: ck auto
Date Posted: December 10, 2003 at 10:39 PM
hi if it doesn't crank long enough you can try reving the car up to about 1200 rpm then program the tach signal. if the starter module has a door on it open it up and you'll see 4 switches one will say tach. start vehicle rev to about 1200 flip switch after tach learned flip switch off and shut car off and retest . if no switches then find programming switch and start car rev to 1200 and press and hold button for 2 seconds .  I msy be wrong on the sequence for the first method its been a while.
good luck
kirk
Posted By: auex
Date Posted: December 10, 2003 at 10:50 PM
First thing, find out if he hooked the tach wire up or if he is using voltage sensing. Second, get the model number of the remote start and that will help alot. Once you get the model of the remote start you can then dl the install manual and will be able to figure out how to up the crank time. It could be is a dipswitch or probably going to be a programming option. As for learning tach with holding the gas down, probably not the best thing to do if it even works at all.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: sroth140
Date Posted: December 11, 2003 at 3:03 AM
actually, DEI techs have had me program the tach wire with a high rev and with the vehicle in gear with the air conditioner turned on (load learn).  it actually works, depending on what the situation is.  chances are the RS in question is on voltage sense.  ive seen a vehicle on tach sense crank for what seemed like 30 seconds before is started, only in extreme  cold weather of course.
Date Posted: December 11, 2003 at 10:40 AM
Ok I have three remote starters so I hope I found the right box.  It turns out to be a Valet 551T.  I found the install manual on the directed website. (Have any of you guys gone to that site recently?  It is REALLY SLOW!)  Apparently I have to locate the module so I can see the red LED.  I thought I would have to add a special programming switch but it looks like the same button that was installed for valet mode is the 'program switch'.  According to the install manual's wiring diagram on page 32 of:
https://www.directed.com/guides/manuals/ig/valet/N551T.pdf
I have to check for a Violet/White wire to see if I have tach sensing.  If it's not connected I'd assume I have voltage sensing.  Page 28 has instructions on Shutdown Diagnostics (my installer was insisting that I keep leaving the car overnight until he could repicate the problem- I assume this is the procedure he was going to go through).  I may wait until the next really cold day to run the diagnostics before I go blindly increase crank time... so far this year it's been good though.
Then tach learning is on page 23, and page 26 has the features programming info which includes crank time setting for voltage sensing setups.
For voltage sensing; I dont understand why there is a crank time.  The manual says the remote starter brain will look for the voltage rise that indicates the car started.  So why have different crank times? Just crank for 5 seconds until the voltage comes up and be done with it?
For tach sensing, what exactly are you programming the brain to recognize? The RPMs that the engine will idle at?  The bran cant control throttle so I dont understand that.
Posted By: auex
Date Posted: December 11, 2003 at 5:09 PM
When you are programming the tach to the brain, it is recognizing when the engine is on ( it tells the alarm that the car is running). As far as the switch for programming the brain, it probably wasn't installed since it is really only used once, just unplug the one for the alarm at the alarm and plug it into the r/s brain. As for the voltage sensing/crank time issue, once the motor is turning the alternator sends voltage, sometimes it is enough to trick the alarm into thinking the vehicle started.
