98 Honda Civic Door locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=22660
Printed Date: April 04, 2026 at 9:26 PM
Topic: 98 Honda Civic Door locks
Posted By: golfnut64
Subject: 98 Honda Civic Door locks
Date Posted: December 10, 2003 at 2:43 PM
Trying to hook up remote locks on 98 Civic ,wire colors called out are Green White &Green Orange when checking these i find voltage on these full time this is supposed to be type B negative system ,i saw somewhere that this is a 3 wire negative setup what does that mean?? My remote puts out Positive or Negative Do i have the
right wires & can i hook up negative output to these? Thanks LB
Lloyd
Posted By: triple110
Date Posted: December 10, 2003 at 6:59 PM
I only had to hook up two wires (I own a 96 civic lx).  Both are located behind the lower right panel next to the steering wheel.  they are next to the fuse box.  It might be easier to use 3M T-connectors because of the tight spacing.  Yes you have the correct wires.
Triple110
Date Posted: January 07, 2004 at 9:40 AM
Thanks I found the correct wires , I had the wrong Unlock wire it was green orange or red ? The right one was Green Tan or something like that But it works now . Thanks again This is a great site   LB
Lloyd
