1998 Ford Ranger Tach Wire
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=22680
Printed Date: April 04, 2026 at 6:49 AM
Topic: 1998 Ford Ranger Tach Wire
Posted By: snowgoer540
Subject: 1998 Ford Ranger Tach Wire
Date Posted: December 10, 2003 at 8:59 PM
I am having trouble finding the tan / YELLOW tach wire for my ranger, the book that came with the alarm system said you were supposed to check for ac voltage at that wire and it should be from 1-6V AC, and then the voltage should increase when the RPM's Increase...However, at that wire, and even the fuel injector wires, there is around 31.5 volts AC, and the voltage Decreases when the RPM's increase...I have distributerless ingition, and i am wondering if this is the correct wire...I dont want to fry my $499 system. Any Suggestions would be appreciated
Posted By: draasch
Date Posted: December 11, 2003 at 10:58 AM
Tach Signal TAN / YELLOW AT POWERTRAIN CONTROL MODULE *
* Powertrain Control Module Is Located On Passenger Rear Of Engine Compartment On The Firewall.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: mark2003
Date Posted: December 11, 2003 at 8:26 PM
Get a tach signal from the coil plug. There should be a 12 volt with key on, so you can use any of the other three wires
